RE: EF Chinn Yak    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: EF Chinn Yak
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: EF Chinn Yak - 3/23/2008 9:21 PM
TailTwister
Score: 105
Last Login: 11/10/2010
Status: offline
Likely, the Ultimate 70 will do the job, but with a little less "left over".
My Chinn Yakk has equal odds at a Saito 72 or 82. It depends on which other plane I crash first, to free up the engine.
_____________________________
Airplane Pimp
Hide Signatures
(in reply to AKFireMedic)
       Post #: 51
RE: EF Chinn Yak - 3/25/2008 6:43 PM
AlexHod
Score: 100
Last Login: 8/14/2011
Status: offline
Hi All,
Who know - what company (except EF) also distribute Chinn Yak-55?
Is anybody try to combo s-63FZ& Yak? Is the anrtivibration mount need to use?
Thanks.
Hide Signatures
(in reply to TailTwister)
       Post #: 52
RE: EF Chinn Yak - 3/26/2008 4:00 AM
TailTwister
Score: 105
Status: offline
It seems Chris has a distributor in Europe, but I'm not sure they carry the entire EF line up. Maybe Chris will pop in to confirm.
Airplane Pimp
Hide Signatures
(in reply to AlexHod)
       Post #: 53
RE: EF Chinn Yak - 3/26/2008 12:35 PM
flyinGraham
Score: 100
Last Login: 5/18/2013
Status: offline
Freestyle-rc are the distributors in Europe and they do carry the entire EF line up, here is their website www.freestyle-rc.com
Graham Roscoe
Hide Signatures
       Post #: 54
RE: EF Chinn Yak - 3/27/2008 12:18 AM
garygee
Score: 105
Last Login: 10/26/2012
Status: offline
Thanks tailtwister for the info.......why do you only use one washer instead of two ?
audaces fortuna iuvat
Hide Signatures
(in reply to flyinGraham)
       Post #: 55
RE: EF Chinn Yak - 3/27/2008 1:03 AM
buildflycrash
Score: 100
Last Login: 5/2/2012
Status: offline
quote:
ORIGINAL: garygee
Just go ahead and buy the thrust plates. They work much better-don't just crush into the wood mount- they're cheep and you will have plenty for you next several progects.
Ask me about
Pensacola FL - Pro Bro & Gaint Scale 3D, June 14 & 15 2008
Hide Signatures
(in reply to garygee)
       Post #: 56
RE: EF Chinn Yak - 3/27/2008 3:41 AM
garygee
Score: 105
Status: offline
OK boys im in on the thrust offset plates. Now can someone tell me where to buy them I cannot find them on OMP's site. Also just ordered some graphics from B and E Graphics to dress up my russian scheme alittle more........will post pics when complete.
Hide Signatures
(in reply to buildflycrash)
       Post #: 57
RE: EF Chinn Yak - 3/27/2008 4:40 AM
TailTwister
Score: 105
Status: offline
I do one washer, just because it feels better for me. I like the thrust line a little closer to center than most folks. I'm in the minority there.
I don't see the plates on the OMP site either. Maybe just call John and see if they still have them or not. Also, Paul Swany used to sell them.
Airplane Pimp
Hide Signatures
       Post #: 58
RE: EF Chinn Yak - 3/27/2008 7:43 PM
buildflycrash
Score: 100
Status: offline
Thrust Plates, Look at bottom of this page.
http://www.swanyshouse.com/mojo/mojo.aspx
Ask me about
Hide Signatures
       Post #: 59
RE: EF Chinn Yak - 3/27/2008 11:55 PM
garygee
Score: 105
Status: offline
thanks for the thread
Hide Signatures
       Post #: 60
RE: EF Chinn Yak - 3/29/2008 6:28 AM
KWJ48
Score: 103
Status: offline
Ok, I know this is going to stupidly overpowered, but I stuck my saito 91 on my yak. Fully built and with no fuel I came in at 4 lbs. 11 oz. I stuck everything I could on the opposite side of the engine to lateral balance it. The engine is mounted pretty far back. When I went to balance CG I started a the beginning 5'' and still had to put the battery in to almost the leading edge of the wing. So I ended up balancing at 5 1/4. I also made it so I can move my battery back when needed. Also I didn't like the hardware. I broke 2 rods trying to screw on the ball swivels. I ended up using some other stuff I had laying around from another kit.
PRO BRO #2567
Hide Signatures
       Post #: 61
RE: EF Chinn Yak - 3/31/2008 1:12 AM
garygee
Score: 105
Status: offline
Hey what are you guys using for throttle servos. I have hitecs all around guess i need to buy a micro ?
Hide Signatures
(in reply to KWJ48)
       Post #: 62
RE: EF Chinn Yak - 3/31/2008 2:05 AM
TailTwister
Score: 105
Status: offline
The HS-85 MG is good, and comes with side mounting tabs that make the job easy.
Airplane Pimp
Hide Signatures
       Post #: 63
RE: EF Chinn Yak - 4/2/2008 7:40 PM
garygee
Score: 105
Status: offline
tailtwister got my offset plate in...what leading edge do I use the fat side or the smaller tappered edge. If I use the fat side it way over the size of two washers, should I cut it in half and start from there ?
Hide Signatures
       Post #: 64
RE: EF Chinn Yak - 4/2/2008 8:07 PM
buildflycrash
Score: 100
Status: offline
The thrust plate is 2 degrees. Cut it about 1/8" bigger than the engine rails put it under the engine rails. It doesn't matter if you use the thick part or the thin area - It's still 2 degrees.
Ask me about
Hide Signatures
       Post #: 65
RE: EF Chinn Yak - 4/2/2008 8:22 PM
TailTwister
Score: 105
Status: offline
Scott is correct. 2=2 no matter what. But, I'd use the thinner part to keep the engine as centered as possible. It won't make a big difference, but that's my $0.02 for the record.
Airplane Pimp
Hide Signatures
       Post #: 66
RE: EF Chinn Yak - 4/2/2008 11:54 PM
garygee
Score: 105
Status: offline
thanks guys
Hide Signatures
       Post #: 67
RE: EF Chinn Yak - 4/4/2008 12:21 AM
moogyman
Score: 100
Last Login: 2/11/2011
Status: offline
Hey all wassup i just ordered a chinn yak for asaito 56 swingina 13 / 4 w .on 30% it wont hahe the snot of an 82 but it flew a 4- 3/ pound tribute ok on 20% whatha think
and i got a alum tubo muffler for it
if i can keep at 4 pounds should work any one have a setup close to this?
Hide Signatures
       Post #: 68
RE: EF Chinn Yak - 4/4/2008 1:24 AM
AKFireMedic
Score: 100
Last Login: 11/24/2010
Status: offline
That's a pretty small engine for this plane. I think it would probably do OK but I'm concerned that it will require a bunch of weight to be added to the nose for balance and negate the weight savings making her pretty sluggish.
Da** it feels good to be a Pro Bro
Hide Signatures
(in reply to moogyman)
       Post #: 69
RE: EF Chinn Yak - 4/4/2008 6:05 AM
moogyman
Score: 100
Status: offline
i do have a 125 layin around hmmm
Hide Signatures
       Post #: 70
RE: EF Chinn Yak - 4/4/2008 6:08 AM
moogyman
Score: 100
Status: offline
illl put the batteries back near the rudder
Hide Signatures
       Post #: 71
RE: EF Chinn Yak - 4/4/2008 9:49 AM
AKFireMedic
Score: 100
Status: offline
That is just silly right there...
I like how you think!
Hide Signatures
       Post #: 72
RE: EF Chinn Yak - 4/4/2008 3:29 PM
moogyman
Score: 100
Status: offline
I know i NEED help Can you say vertical 80mph torque roll
Hide Signatures
       Post #: 73
RE: EF Chinn Yak - 4/5/2008 1:24 AM
KWJ48
Score: 103
Status: offline
quote:
ORIGINAL: moogyman
And I thought I had too much. Just a little info If you do go with a 125... Get longer landing, the prop probaly won't clear. I'm kinda close to the pavement in my driveway with a 14x6
PRO BRO #2567
Hide Signatures
       Post #: 74
RE: EF Chinn Yak - 4/5/2008 2:11 AM
garygee
Score: 105
Status: offline
moogyman I have to see this ........please make sure you record your 1st flight.
Hide Signatures
(in reply to KWJ48)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.672RCU1
