YellowAircraft
Joined: 1/5/2002 From: San Diego, CA, USA Status: offline
Sean, Thanks, buddy. Invertmast, CST is having a sale on carbon plate 1/8"x3"x12" across. That's what I used. You only need to get it across that narrow spot a ways like in my pic. Remember that the front bulkhead you're gonna get will already have s layer of 6-oz carbon cloth between the main ply and the doubler ply. Even if you use your 1/16" diamond plate, I think you'll be alright. I felt better about the 1/8" carbon, though... Jeff, Interestingly, that's the method we use on the F-15. I'm guessing the fact that the fins on that one are 90 degrees straight up makes it easier to get the geometry right with the little stab/fin control-yoke-box-dealeo. Looking at the pics in the one you show, I see the idea, but i'd be concerned about a positive, slop/bind-free rudder. I'm sure his is fine, but I'd probably end up with some kind of a problem. The only thing I don't like about removing the rudder is the way the wire is stowed. That looks like it's gonna be a PITA. The removal of the rudder itself is easy (and kinda cool if you ask me) if it's anything like the flaperons on the F-16. I don't intend to do the wood plug in the top of the fin deal. I'll just have the tip of that wire bent back and sitting up there as inconspicuously as possible. I'll just tell myself that it's some kind of antenna or sensor that the real one has... What I aint gonna do is put the servo in the fin. I've never understood why people do that and ruin one of the nicer features of this bird--no exposed linkages! Some say you get more positive control or whatever, but all I see is an ugly fin and rudder linkage hanging out and more lead in the nose. With the proper hardware, there doesn't need to be any more slop or flex with the servos up near the rear of the hatch. You get shorter servo leads, too. Does anyone know if there's a good bandsaw blade for carbon plate? I've gone through two of the stock metal-cutting blades you get at home depot, and they would barely cut balsa at this point. How are those of you without exotic equipment at your disposal cutting your carbon?
_____________________________
Yellow Aircraft, JetCat Engines, Skymaster ARF+ and Turn Key Jets www.cyctheatre.com
