RE: Yellow Aircraft F/A-18C Twin (Two Engines) KIT Full Build BUILDER'S Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Yellow Aircraft F/A-18C Twin (Two Engines) KIT Full Build BUILDER'S Thread
Page: <<   < prev  16 17 18 19 20 21 22 23 24 [25]
Login
RE: Yellow Aircraft F/A-18C Tw... - 6/30/2008 8:04:20 PM
grbaker
Status: offline
quote:
my turbine is a AMT 180..... hopefuly its enough thrust......?
Chris,
It should be plenty. I've seen one fly on 7# thrust. Where do you fly?
_____________________________
Gary Baker
(in reply to yeahbaby)
       Post #: 601
RE: Yellow Aircraft F/A-18C Tw... - 6/30/2008 11:12:57 PM
sKrUb_69
Status: offline
grbaker dont realy have a flyin field yet. been mostly flyin at outlaw fields, but lookin to get my AMA card......lol never thought i was going to need one but will get it as soon as i finish my build. But i do plan on attending the Texas fly ins when they come back around providing im through building. i still need to get the scuba tank hook up so I can start the turbine. i have never started it yet and im dieing to start it...... But thanks for the advise i will figure a way to beef up the mains structure.... some how.......? not much room but will try my best. but here is a couple more pics.. one is the front were the battery for the ecu and the 2 air tanks are. and the other the gryo im going to use...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Chris H.
Y/A F-18 single Turbine AMT Turbines
(in reply to grbaker)
       Post #: 602
RE: Yellow Aircraft F/A-18C T... - 6/30/2008 11:15:43 PM
sKrUb_69
Status: offline
wwooooooo....what the heck happend.......? talk about over sized pics.....LOL my bad guys..
Chris H.
(in reply to sKrUb_69)
       Post #: 603
RE: Yellow Aircraft F/A-18C T... - 7/1/2008 2:43:28 AM
invertmast
Status: online
nick,
glad ya liked the tires... yea the funds showed up last week i believe. thanks again
Thomas W.
Avant FX, Trex 600N, YA F-18 Twin, Ziroli Panther..
       Post #: 604
RE: Yellow Aircraft F/A-18C T... - 7/2/2008 4:58:08 PM
YellowAircraft
Status: offline
Hey,
I'm in a bit of a conundrum (sp?) with something. The way my radio gear is situated like this: The pumps and solenoids are on a tray above the nose-gear mount. The receiver is on the same tray as the ECU's (with about two inches seperation), sitting two inches above the aforementioned tray. I know you're supposed to isolate the engine electronics from the radio electronics, but space is at a major premium in here. Ideas?
Yellow Aircraft, JetCat Engines, Skymaster ARF+ and Turn Key Jets
www.cyctheatre.com
(in reply to invertmast)
       Post #: 605
RE: Yellow Aircraft F/A-18C T... - 7/2/2008 11:19:28 PM
invertmast
Status: online
Shaun,
I know what your going thru their! hence the reason i decided to stuff my UATS up by the nose gear plate and the reciever under the middle hatch. Would it be a possibility for you to put the reciever either ontop of the tanks or on the forward side of the front wing spar bulkhead?
Thomas W.
(in reply to YellowAircraft)
       Post #: 606
RE: Yellow Aircraft F/A-18C T... - 7/3/2008 1:42:13 AM
bskyinc
Status: offline
Shaun, why not locate the Ecu's above the inlets in the engine bay forward of the bypasses, put the pumps/solenoids in the hatch just forward of the engine bay, and the uat's and receiver on the plate above the nose gear mount. Had my SM f18 Ecu there and that's also where the ECU is in my Yelllow F15. Puts lots of distance between ecu's and pumps and the receiver. Also the plug in for the data terminal (jetcentral) is in the ecu so makes it handy for hookup since engine hatch is off for startup. I know Jet Cat uses a separate board for Data terminal connection, but that could also be located aft. Steve
       Post #: 607
RE: Yellow Aircraft F/A-18C T... - 7/23/2008 12:13:10 AM
seanreit
Status: offline
Shaun, I have finished the "washers" for the landing gear. They are $30.00 shipped for two. I need your address to send them to you.
Anyone else need them, let me know.
I'll let Shaun or Steve explain what they are for, cause I'm not really sure, I was just given a drawing on this, and I made it within a couple thousandths.
(in reply to bskyinc)
       Post #: 608
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
