CX2 Blade Grip Upgrade Help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> CX2 Blade Grip Upgrade Help
Page: [1]
Login
CX2 Blade Grip Upgrade Help - 2/21/2008 1:17:10 AM
rc4play
Status: offline
As I view the options available I get more confused , so can someone tell me what is best.
Xtreme CNC Blade Grips w/ Blades or Microheli CNC Blade Grips w/ Exxtreme Blades ( I beleive I saw 2 different types of CNC Grips they sell)
Then there is also the Microheli Exxtreme Core V.2.0 which looks to be plastic ?
All Microheli I believe are Folding blade type, HELP ! What is better, more durable, or any other input you could provide based on your experience.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 1:34:39 AM
rikybob
Status: offline
I don't have any of the above but everything points me in the direction of keepin' me stock stix! Mine perform admirly and it seems to me that unless you just want the bling, just replace the other parts that seem to break more............like the lower rotor.........just me 2 cents..............good luck on whatever endeavor you choose!
Rikybob
_____________________________
"Trust, then verify"; or: Calm dayz and long lipoz!
(in reply to rc4play)
       Post #: 2
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 1:41:25 AM
weare5
Status: offline
The 3rd one with the shafts is the best one. But buy it with the everything, mine flies so much better and stronger.
(in reply to rikybob)
       Post #: 3
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 1:51:48 AM
evdreamer
Status: online
Don't buy that plastic one from the extreme core. The parts are from the Dynam Vortex. It will cost a 1/4-1/2 price buying the Vortex parts compared to the cost of the extreme core.
Since I started this hobby money seems to keep disappearing. :)
T-Rex 450SEV2, Gaui 200 SD
       Post #: 4
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 4:00:47 AM
BarkingDogs
Status: offline
anybody know how the Xtreme Alum. Blade grip combo. from Boomtown hobbies $43 works with the aluminum EFlight heads , Eflight aluminum swashplate, short flybar and stock shafts? I've heard boomtown service is great. thanks
(in reply to evdreamer)
       Post #: 5
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 4:32:30 AM
evdreamer
Status: online
I haven't tried it with the aluminum upper head, but it works fine with the stock shafts, E-flite aluminum swashplate, and E-flite aluminum lower rotor head.
(in reply to BarkingDogs)
       Post #: 6
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 4:41:52 AM
ArrowNaughtic
Status: offline
quote:
ORIGINAL: weare5
A wise man spends money wisely.................. Well, you know how that goes. Sadly no one really does much investigating before spending thier days salary to line the pockets of someone who found out early how to interchange pieces and tout them as thier own design. Go to www.bphobbies.com and check out the Dynam vortex parts listing. Look at the flybar, inner shaft and outer shaft with gear, price them and then look at what the other guy sells his "kit" for. Notice the amazing non difference of parts? look at the price difference.....................
If it works for you then I say good for ya but I got the same parts for 15 bucks shipped to my door.
_____________________________________________________________________________________
Of all the things I ever lost....................................... I miss my mind the most!
(in reply to weare5)
       Post #: 7
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 6:02:36 AM
eat2muchrice
Status: offline
I've been eyeing the first one (new micro heli's grips) for months, they weigh only 3....somthing grams. My biggest problem is forking over $60 for them. If you decide to get them please please do a review on the forums for us.
I've also tried just the plastic grips on the 3rd picture (extreme) without much luck.(sent them back), But have heard the whole core is better. Try arrows idea.
<<--- My dogs first look and sniff at her worst nightmare.
(in reply to ArrowNaughtic)
       Post #: 8
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 1:46:22 PM
Drewed
Status: offline
I have the second from the left and have not been happy with them. They required sanding of small spacers before they would fit with out binding, and I have had TBE since I installed them. I would go with the on the right.
(in reply to eat2muchrice)
       Post #: 9
RE: CX2 Blade Grip Upgrade Help - 2/21/2008 2:59:06 PM
Edwinssiv
Status: offline
I have the end one on the right coming from Boomtown...should be here on Friday...I will let you know how they work
Blade CX2/Axe CP/ Trex 450 SE v2/Gazaur Mars 480/TRex 500 GF
(in reply to Drewed)
       Post #: 10
RE: CX2 Blade Grip Upgrade Help - 3/7/2008 4:53:23 AM
sonat
Status: offline
quote:
ORIGINAL: evdreamer
www.bladecx2.com
getting very tire of peoples that said our parts are vortex
before making comment on something be sure to verifiled what you said
is this clear or not
Sonny Lambert
President of bladecx2.com
       Post #: 11
RE: CX2 Blade Grip Upgrade Help - 3/9/2008 9:48:32 PM
paulwhite
Status: offline
I've fitted the extreme core grip blades. Now I cant seem to stop my heli moving in a clockwise 5ft circle. The nose stay pointing forward. it cant be the trim as on its journey its moving backwards and forwards if you see what I mean. Any Idears. What does the fly bar do??.
(in reply to sonat)
       Post #: 12
RE: CX2 Blade Grip Upgrade Help - 7/19/2008 4:55:16 AM
stump3r
Status: offline
rc4 I've been flying the Xtreme blades, grips, Eflite CNC upper hub, swash plate and micro heli CNC lower hub for almost a year now. Great stuff you'll have now problems at all. It does take a bit to get her trimmed right but once you get it you won't ever go back to stock.
Life is tough. It''s even tougher when your stupid! - John Wayne
CX2, FourKing FP, CX450SEV2, DX7
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
