Painting with KlassKote... fisheyes
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Painting with KlassKote... fisheyes
Page: [1]
Login
Painting with KlassKote... fisheyes - 2/21/2008 1:51:40 AM
wkevinm
Status: offline
I am preparing a plug of a fuse for molding and in the final stages of preparation I am trying to ge the best finish I can on the plug. I have primed with grey primer, sanded, primed, sanded, again and again. I had finished sanding with 320 wet and dry and hit it with a heavy coat of paint, ... lots of fisheyes, re sanded, hit with several light coats, no fish eyes, sanded with 600 grit wet and dry, hit with a light coat of KlassKote, let dry to a tack then hit it with a heavy coat of klasskote, more fisheyes.
I am using red with gloss catalyst, mixed, let sit for 45 minutes then thinned 50% with klasskote reducer. I am using an aibrush for painting, air is dried to -20C (at least thats how cold my garage was when I got the air tank filled). Air pressure 30PSI.
What can be done to reduce the fisheye, I know I can sand and finish with 1200 - 2,000 then polish but I wanted the wet look when I am done spraying.
Any recommendations?
Kevin M.
< Message edited by wkevinm -- 2/21/2008 1:52:27 AM >
       Post #: 1
RE: Painting with KlassKote... fisheyes - 2/21/2008 3:40:44 AM
KC36330
Status: offline
fish eyes are from contamination, oil and water being the two most likely, are you using a separator on your air supply??
(in reply to wkevinm)
       Post #: 2
RE: Painting with KlassKote... fisheyes - 2/21/2008 7:07:52 AM
rmenke
Status: offline
wkevinm
Sounds like you are gathering a lot of weight there. Best remove to past the original fisheyes, or they just may come back regardless. Gotta have a seperator in the system, before or after the regulator or at the gun, but something to keep the junk out. Love the Klasskote, one of the few paints I don't screw up regularly, very user friendly even with my 40 year old Jacussi sic compressor. Try Lowes tool center, have several decent reasonable cost dryer/seperators. ENJOY
       Post #: 3
RE: Painting with KlassKote... fisheyes - 2/21/2008 1:42:32 PM
Ed Smith
Status: offline
Are you cleaning the part immediately prior to painting? Just before I paint I wipe the part with a soft cloth and an automotive cleaner. The cleaner removes all grease, fingerptints, sanding residue etc,etc, and evaporates quickly leaving a dry surface free of contaminates.
Ed S
       Post #: 4
RE: Painting with KlassKote... fisheyes - 2/21/2008 2:19:10 PM
daven
Status: online
It also sounds like you may be reducing too much.
I mix 1/3 color, 1/3 catalyst and wait 1/2 hour. Then 1/3 reducer just before I pour it through a paint strainer, into the gun.
I spray at 20-25 psi with great results.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to Ed Smith)
       Post #: 5
RE: Painting with KlassKote... fisheyes - 2/21/2008 3:30:34 PM
wkevinm
Status: offline
Good advise from all, I will include a separator in the air supply, wipe down just prior to spraying, strain and adjust the amount of reducer.
Thanks, Kevin M
(in reply to daven)
       Post #: 6
RE: Painting with KlassKote... fisheyes - 2/21/2008 10:58:11 PM
Viper Driver
Status: offline
One more step to surface prep is to go over the entire plug with a tack cloth. The tack cloth should be the final step, just prior to painting. Back when I used to paint with K&B (essentially Klass Kote) I learned this lesson the hard way, and the tack cloth cured the problem.
Jeff
< Message edited by Viper Driver -- 2/21/2008 10:59:57 PM >
Jeff "Deadeye" Carder
Vipers Rule!
       Post #: 7
RE: Painting with KlassKote... fisheyes - 2/23/2008 12:53:31 AM
Kevin Matney
Status: offline
Hi
It took me a long time to paint with K&B paint. As for Klass Coat it will spray the same. The first thing is to spray a dust cost, I really mean a dry cost of paint and let tack for 15 to 20 min. Why I say this you need the surface to stick the paint too. If you put on to much paint the first time it will allways fisheye on you. Then put on the next coat and let tack off 5 min this time Then 1 more coat if needed. Or go back with just thinner in the gun to wet out the paint and get a realy glossly finsh
Kevin Matney 2 wrongs don't make a right But 2 Wrights make an Airplane
www.Matneymodels.com
(in reply to Viper Driver)
       Post #: 8
RE: Painting with KlassKote... fisheyes - 2/23/2008 1:45:28 AM
dhal22
Status: offline
i have just about seen enough to convince me to use klasskote for painting my next project. some of the deep, glossy finishes i've seen are superb. i need to go to the website and start reading i suppose.
david
(in reply to Kevin Matney)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
