darkith
Joined: 2/19/2007 From: Fredericton, NB, CANADA Status: offline
ARGH! Finished up almost all the code, testing against my Futaba TX & Hitec RX. Works great. Tested it with my Spektrum DX7 & AR6100, and nothing was working. Find out that the Spektrum RX puts out an ever so slightly lower voltage on it's servo channels, which the PIC doesn't detect reliably. I'm going to have to redesign the inputs, but that shouldn't take too long...I hope. I have the basic features working great. recoil blocking option no-superspin option momentum option weight classes (light, med, heavy) 3 sound outputs (fire, hit, destroyed). Can use one sound card (either with hit&fire(HL recoil/sound blocked), or hit&destroyed(use HL fire sound)) or two cards with all three sounds. LED cannon flash driver settings via radio after setting jumper (only one onboard jumper) 4 channel radio required Driver for micro servo to recoil barrel (voltage regulator may require extra heatsinking) Still working on: 5 channel radio for better control Engine startup is handled by blipping full throttle. The Engine will shutdown if the radio signal is lost, and will startup again once it's found. Battling is disabled when the engine gets shutdown. These are the controls in four channel mode: Throttle Steering Turret rotation And "Gun". -full up: elevation cycles -part up: MG fires -part down: airsoft cycles and fires -full down: main cannon (and IR firing) Once I get the new design done and tested, I'll probably start taking pre-orders to gauge the actual interest, and ensure there's enough buyers before bringing in a bunch of parts (from even more vendors than the regular DBC). Cheers, David
_____________________________
RCU Required Disclosure: Manufacturer of DBC battle circuit for Heng Long tanks.
