blitzkrieg65
CA, USA Status: offline
quote:
ORIGINAL: darkith @YHR, The DBC-RC2HL has an onboard voltage regulator fed from the 3-wire Heng Long cable, so no need to tap power from the board. You''''ll still need to solder on a connector if you want to hookup a sound card though. @Planedev, I don''''t see why not. You''''d want to be careful not to fry the mic or PCB, but it sounds doable. Keep in mind that the Heng Long sound system isn''''t exactly hi-fi, so a little bit of noise (which you''''ll may hear with the speaker directly connected) is probably going to be drown out by the sound system and engine noise. @blitzkrieg, The soundcards I ship *don''''t* come pre-recorded. It''''s pretty simple to record them though, and it''''s pretty neat to be able to customize the sound. I think it was YHR that had a tank play "Taps" when it died. Cheers, D. Oh David thats right you have it programmed so the engine die sound goes off when the unit dies, is that it? The Blitz
