rcluke
Joined: 11/13/2006 From: middlesbrough, UNITED KINGDOM Status: offline
TA-05R the different parts are, quote:
from Tamiya america About the Model * All-new aluminum center plate, blue anodized aluminum spur gear holder, and carbon fiber damper stays reinforce the chassis while reducing weight. * Impressive list of included option and spare parts: 51000 High Torque Servo Saver (Black) $8.25 MSRP 51065 TRF415 Suspension Mount (A) $10.50 MSRP 51068 TRF415 Suspension Mount (D) $10.50 MSRP 53539 5.5mm Aluminum Spacer Set $8.75 MSRP 53640 5mm Aluminum Bolt Nut (Blue) $7.50 MSRP 53642 5mm Aluminum Ball Connector (Blue) $7.50 MSRP 53644 Aluminum Stabilizer End (Blue) $6.50 MSRP 53685 TRF415 Front Bridge Suspension Mount (A) $14.00 MSRP 53823 Clamp Type Aluminum Wheel Hub (5mm thick) $21.00 MSRP 53836 48mm Swing Shafts for Assembly Universal Shaft Set $15.00 MSRP 53849 TA05 High Precision Diff Joint $18.00 MSRP 53857 04 GP Spur Gear 105T (TA05) $4.30 MSRP 53869 5mm Aluminum Short Ball Nut (Blue) $10.00 MSRP 53871 48mm Lightweight Rear Swing Shafts (Blue) $16.00 MSRP 53874 TA05 High Precision Center Pulley Bushing $3.60 MSRP 53894 TA05 Carbon Reinforced A Parts $18.50 MSRP 53895 TA05 Carbon Reinforced K Parts $9.25 MSRP 53897 TA05 Aramid Drive Belt (Blue) $9.00 MSRP 53899 Reversible Lightweight Suspension Set $117.00 MSRP 53918 TRF Damper Low-Friction V Parts $6.00 MSRP 53935 TA05 Wide Pitch Diff Pulley $6.75 MSRP 53571 TRF Fluorine Coated Damper $76.00 MSRP 53842 TA05 Stabilizer Set (F&R) $18.00 MSRP * TRF Dampers (Blue), Damper Springs (White), Front/Rear Stabilizers, and Aluminum Turnbuckle Shaft (Blue) are also included in this assembly kit. * R/C system, ESC, battery, body, motor, tires, and pinion gears are sold separately.
_____________________________
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05 NOVAK OR NOTHING
