RE: The Official Tamiya TA05 Thread
Tower Hobbies
Logged in as Guest
Users viewing this topic: rcluke
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: The Official Tamiya TA05 Thread
Page: <<   < prev  12 13 [14] 15 16 17 18 19 20 21   next >   >>
Login
RE: The Official Tamiya TA05 Thread - 5/13/2008 1:55:56 AM
steve6sucks
Status: offline
So for you guys running the TRF Special Dampers, how did you set them up? The instructions make no reference to the TA05 chassis in terms of which piston (2 or 3 hole) or shock oil to use. I'd like them to feel similar to the CVA dampers that come stock. Any ideas?
(in reply to mkoresh12)
       Post #: 326
RE: The Official Tamiya TA05 Thread - 5/13/2008 7:52:19 AM
rcluke
Status: online
quote:
ORIGINAL: steve6sucks
put the same hole piston as the CVA's on.
shock oil is all about what track you run on, for tarmac you want the oil pretty hard, for carpet, medium sorta weight, and for polished wood, soft oil
_____________________________
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
(in reply to steve6sucks)
       Post #: 327
RE: The Official Tamiya TA05 Thread - 5/13/2008 4:29:23 PM
Bimmerdriver330ci
Status: offline
Hi, got a TA05 with a mamba max in it. Its sick, but I keep snapping my plastic diff cups in the rear. I even detuned my engine. Still snap them. I have a front one-way unit, but I dont want to lose reverse. Does tamiya or any other company make metal rear diff cups. Spent so long searching Im tired of it. Even my hobby shop cant help me. Takes too long to order from them. Thanks guys. Looking forward to being a member here.
(in reply to rcluke)
       Post #: 328
RE: The Official Tamiya TA05 Thread - 5/13/2008 5:29:57 PM
rcluke
Status: online
quote:
ORIGINAL: Bimmerdriver330ci
tamiya JUST released metal cups, ill try and find you a link
NOVAK OR NOTHING
(in reply to Bimmerdriver330ci)
       Post #: 329
RE: The Official Tamiya TA05 Thread - 5/13/2008 5:40:10 PM
Bimmerdriver330ci
Status: offline
That is awesome thanks man. Oh and I have the same body on mine....its a little beat up but I like it. Hey I posted elsewhere also and he found it at horizon. Thanks again for your help.
< Message edited by Bimmerdriver330ci -- 5/13/2008 5:54:55 PM >
       Post #: 330
RE: The Official Tamiya TA05 Thread - 5/13/2008 5:57:31 PM
rcluke
Status: online
53849
53919
NOVAK OR NOTHING
       Post #: 331
RE: The Official Tamiya TA05 Thread - 5/13/2008 6:00:38 PM
Bimmerdriver330ci
Status: offline
What does the precision diff do?
       Post #: 332
RE: The Official Tamiya TA05 Thread - 5/13/2008 6:14:47 PM
rcluke
Status: online
i think it is just a metal one
as with most Tamiya precision parts, they are just made to a higher quality (with a tighter quality control tolerance) than the standard parts
NOVAK OR NOTHING
       Post #: 333
RE: The Official Tamiya TA05 Thread - 5/13/2008 10:32:50 PM
mkoresh12
Status: offline
quote:
ORIGINAL: rcluke
The precision are not metal. They are made to higher tolerances plus have a ring that keeps the dog bone from falling out.
       Post #: 334
RE: The Official Tamiya TA05 Thread - 5/13/2008 10:42:42 PM
steve6sucks
Status: offline
quote:
ORIGINAL: rcluke
Thanks for your advice. I'll be running mostly on tarmac so I guess a hard oil is the way to go. My CVA's currently have single hole pistons in them and the TRF dampers only come with either two or three hole pistons. I'm using the yellow #400 oil so I guess I'll just use the two hole pistons and go up a bit in oil weight. Any suggestions for which weight of oil?
       Post #: 335
RE: The Official Tamiya TA05 Thread - 5/14/2008 8:09:54 AM
rcluke
Status: online
quote:
ORIGINAL: mkoresh12
quote:
ORIGINAL: rcluke
thanks for correcting that up for me, i have them on the front of my '05, but i havent really looked at them
NOVAK OR NOTHING
       Post #: 336
RE: The Official Tamiya TA05 Thread - 5/19/2008 1:26:30 AM
mkoresh12
Status: offline
Well, another bad day of racing for the TA05. Most of it was my fault. I got the car to hookup this weekend so it handled awesome. But, I nicked a corner and broke the upper and lower king pins and damaged the front upright. I was able to get it hold together for a while longer(3rd qualifier and most of the main). I was late getting into the main(someone didn't turn in the transponder). So, in my rush I forgot one of the pins that hold the battery in. I think we can see where this is going. About 4 laps in (I was kicking butt too), the battery when flying out. I was really confused until I got the shell off and realized that I forgot the pin. Got the pin in so I could finish the heat, then a couple laps later the upright I damaged earlier fell off again and that was it. If I can keep from hitting the inside corners so hard I think I'll have the TA05 in contention. My per lap times are not much off from the others if I can finish a race. Not bad considering I'm running against all TC5's and xrays.
       Post #: 337
RE: The Official Tamiya TA05 Thread - 5/19/2008 3:26:11 AM
Mad Fox
Status: offline
Just fitted a HellFire 27T motor in my 05 IFS was hoping to test the sucker out in the carpark where I go but unfortunatley they had locked up for the night, my son was miffed too as we had just finished building his 05 IFS Ebro, (he's usin a Scoobie shell instead of the Ebro shell, so I'm nickin off with it lol), and he was eager to test it and do the fine tuning, oh well maybe another night....
"It is far better to deserve honours and have none, then to have honours and not deserve them".
       Post #: 338
RE: The Official Tamiya TA05 Thread - 5/19/2008 10:57:59 AM
stealthbomber
Status: offline
Hello, if you guys have time, please help me out a bit
http://www.rcuniverse.com/forum/m_7507397/anchors_7513364/mpage_1/key_/anchor/tm.htm#7513364
My cars :Stampede : TT-01,Thundershot,F103Gt http://kuvablogi.com/blog/4540/
http://www.youtube.com/user/RangerPate
(in reply to Mad Fox)
