RE: The Official Tamiya TA05 Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: The Official Tamiya TA05 Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: The Official Tamiya TA05 Thread - 3/12/2008 8:34:47 PM
mkoresh12
Status: offline
I actually started out with that one until I switched to a JRxs3 so that I didn't have to worry about crystals. The RS300 receiver is large, I just got in a RS310 micro receiver so I can keep the same radio. I put the futaba in my sons car. It is a good receiver tho.
(in reply to rcluke)
       Post #: 51
RE: The Official Tamiya TA05 Thread - 3/12/2008 10:13:28 PM
rcluke
Status: offline
quote:
ORIGINAL: mkoresh12
i run it in all of my cars, it fits perfectly into the frame at the back of the M-03
_____________________________
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
(in reply to mkoresh12)
       Post #: 52
RE: The Official Tamiya TA05 Thread - 3/16/2008 12:39:15 AM
rcluke
Status: offline
i raced the TA-05 tonight, and came 3rd in the final (against 4 other's)
I now have the TRF shocks on, and am running 300weight oil all-round, with the Tamiya blue springs on the front and yellow on the back. I am also running a RED sway bar on the rear, and nothing on the front.
With 26mm wide mini-pins, this is a good set-up for polished wood floor. (i am running a 19x1 motor)
NOVAK OR NOTHING
       Post #: 53
RE: The Official Tamiya TA05 Thread - 3/16/2008 11:03:09 AM
kiki46
Status: offline
Well done Luke, how did you come to that setup? I found an improvement when I changed from the 26mm minipins to the 21mm, not as smooth but faster time. Kieran.
       Post #: 54
RE: The Official Tamiya TA05 Thread - 3/16/2008 11:39:59 AM
rcluke
Status: offline
quote:
ORIGINAL: kiki46
i put the new shocks on, then i thought it would be better having them with soft oil, so they dig in easier.
i might get some of the narrower ones, but i have just bought a new set of the wide ones
NOVAK OR NOTHING
(in reply to kiki46)
       Post #: 55
RE: The Official Tamiya TA05 Thread - 3/19/2008 3:12:14 AM
mkoresh12
Status: offline
Hey rcluke, did you ever get your overheating ESC fixed? If so how did you do it?
       Post #: 56
RE: The Official Tamiya TA05 Thread - 3/19/2008 5:32:14 PM
rcluke
Status: offline
quote:
ORIGINAL: mkoresh12
yep here's the How - To
step 1, remove old ESC
step 2, Purchase new ESC
step 3, apply double sided tape to the ESC bottom
step 4, set-up ESC
step 5, NO OVERHEATING
NOVAK OR NOTHING
       Post #: 57
RE: The Official Tamiya TA05 Thread - 3/19/2008 5:46:48 PM
mkoresh12
Status: offline
well, thats definately one way to do it. What kind of ESC did you get? I had the futaba mc230 but its only down to 20 turns. Was fine for me as we only race stock class. Nice small ESC, I now have the novak GTB since I'm running 13.5 brushless.
       Post #: 58
RE: The Official Tamiya TA05 Thread - 3/19/2008 5:53:57 PM
rcluke
Status: offline
quote:
ORIGINAL: mkoresh12
Novak XRS Sport
http://modelsport.co.uk/?CallFunction=ShowSpecification&ItemID=18265
how much was your b/l, i'm thinking of getting one when i am a bit better
NOVAK OR NOTHING
       Post #: 59
RE: The Official Tamiya TA05 Thread - 3/20/2008 1:18:37 AM
mkoresh12
Status: offline
At tower the set goes for 259.99usd. I got mine a little cheaper. I got the GTB new on ebay for 80usd and purchased the motor from tower for 79.99-20 coupon. From what the guys that bought them pre-soldered told me the wires were too long and they had to cut and re-solder them anyway. Great set-up and even tho the 13.5 is supposed to be comparable to a stock brushed I don't think that is right. The 13.5 brushless is much faster in my ta05. The motor stays cooler and I can gear it down alot more.
       Post #: 60
RE: The Official Tamiya TA05 Thread - 3/20/2008 8:21:02 PM
rcluke
Status: offline
quote:
ORIGINAL: mkoresh12
nice
what gearing do you use?, 64dp?
NOVAK OR NOTHING
       Post #: 61
RE: The Official Tamiya TA05 Thread - 3/20/2008 9:02:24 PM
mkoresh12
Status: offline
I was going to go 64p but the lhs mainly carries 48p. I switched from Standard from Metric as they don't carry anything metric there. Just makes it easier to change gearing. To tell the truth I haven't had the car out since last summer so I can't remember what spur and pinion are in it. I know my final was about 5:1. Whenever I got lower than 6.5:1 with the brushed motor it would start to overheat. The 5:1 on the brushless barely gets warm.
       Post #: 62
RE: The Official Tamiya TA05 Thread - 3/22/2008 6:22:15 AM
thaphillips
Status: offline
quote:
ORIGINAL: mkoresh12
17.5T Brushless = 27T Brushed
Brushed still is a little faster here.
(TA05-Exige-RS 540 BL1)(M03-Exige-RS 540 BL1)
http://thaphillips.mylaps.com
       Post #: 63
RE: The Official Tamiya TA05 Thread - 3/22/2008 2:31:21 PM
mkoresh12
Status: offline
quote:
ORIGINAL: thaphillips
quote:
ORIGINAL: mkoresh12
From a practical standpoint I'd agree. But going just by kv rating and race rules/classes, 13.5 is still considered stock. 13.5 is rated at 3,000/volt. 7.2v*3000rpm=21,600. The CO27 pro motor I had was rated at 19,000rpm@5v. The Orion Core Stock I have is rated at 25k@7.2v. Watching the performance on the track the 13.5brushless seems to be much faster than just going by its kv rating. I haven't seen a 17.5 brushless so I can't compare that one but in the real world it may be closer to stock.
All rpms are unloaded.
< Message edited by mkoresh12 -- 3/22/2008 2:33:28 PM >
(in reply to thaphillips)
       Post #: 64
RE: The Official Tamiya TA05 Thread - 3/22/2008 3:10:17 PM
rcluke
Status: offline
