mkoresh12
Joined: 2/12/2007 From: Burton, MI, USA Status: offline
quote:
ORIGINAL: HSVXU6 Hi all. I have just ordered a TA05 and I hope that it will be here next week, have to wait and see. I have built up a TL01 BL and have been using that and have been really enjoying it. I went and watched racing for the first time in 25 years and it has got me motivated to join a club and go racing. The guys that we have meet at the club have been great to talk to and are most welcoming. I think that buying a TA05 will give me a better handling car than my poor old TL01 but it is great fun and I will keep it for running around the roads near home. If you have any suggestions regarding the build and set up of the car it would be most appreciated, thanks all. The TA05 is a great handling car. Regarding the build the main things would be, stay organized. Keep the parts bags together, one tip I heard is to transfer your metal parts bags to ziploc baggies and keep the label from the parts bag in there. The other thing is make sure you correctly tighten the ball diff. The lock nut will strip if you overtighten. Might not be a bad idea to get some extra diff bolts and nuts to begin with. The HPI RS4 uses the same diff bolt nut so there is another source for the part if needed.(tamiya parts are hard to get by me) As for setup, the stock setup actually handles very well. I''d keep it there initially then fine tune to your driving style later. I just added foam tires to my car and away I went as far as setup.
