VulcanGrey
Joined: 2/21/2008 From: Loveland, CO, USA Status: offline
I recently bought a 60B chassis, with all the aluminum parts already installed, on ebay for $30 +shipping argh didn't notice that until it was too late. It didn't include any of the elctrics, so I bought everything seperate. I have a Futaba 9CH radio and for the Walkera 60B I got these components 1)Elf Hobbies brushless motor and 35A ESC, with the beveled pinion. ($40 at Ehirobo) 2)Futaba GY401 ($95 on ebay) 3)3x Hitec HS-65MG servos ($35ea at hobby store) I did have to make my own servo mounts for these, used 5052 aluminum similar to the original mounts. 4)Hitec HS-81 for the tail servo 5)1500mAh 3S 20C Li-Po battery from hobby city for $20 6)Castle Creations berg7 7ch receiver ($44 on 20% sale in march) So for alot less than a TREX I have something that might be fairly good, maybe until it crashes. But then the parts are very cheap and easy to get. I also got a full set of the metal upgrades (head, swash, tail, boom, linkages, and 4 spare blades) for $27 on ebay incase I crash. All of these parts, with the exception of the Elf Hobbies brushless motor could be moved to a Trex or Beam 450 size heli in the future if I want to. I like the simplicity of the Walkera 60B head, it is a much better design than the regular Walkera 60# head design. I mounted the receiver in the chassis and mounted the battery up front, for correct balance, and bent the plate to allow it all to fit in the canopy. I also have a Walkera h1#b, that is all stock, and though I heavily crashed it yesterday, it is still easy and cheap to fix. I have not had problems with the Walkera electronics on the 1b so far.
< Message edited by VulcanGrey -- 4/4/2008 12:11:58 AM >
