My first SPAD - checking to see if design will work
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> My first SPAD - checking to see if design will work
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
My first SPAD - checking to see if design will work - 4/30/2003 5:39:24 PM
rchawaii
Status: offline
What I was suggesting is a one piece fuse-coro- it won't split from nose to tail. I didn't see the piggybacking tank idea sorry but probably not necessary and adding to your grief.
_____________________________
[center][link=http://spadworld.net/]If You Can't build it, don't fly it.[/link][/center][hr][center]Click to go to the SPADW
(in reply to guinea13)
       Post #: 51
My first SPAD - checking to see if design will work - 4/30/2003 5:42:03 PM
guinea13
Status: offline
I appreciate the ideas. I am going to fix this one and then make another spare out of coro. I just thought it would be cool idea to add a secondary tank. Guess it had more drawbacks then it had benifit. Now I have a spare 2 oz. tank. Any ideas of what to do with it?
       Post #: 52
My first SPAD - checking to see if design will work - 4/30/2003 5:45:31 PM
rchawaii
Status: offline
yeah, build another spad and fly the snot out of it
       Post #: 53
My first SPAD - checking to see if design will work - 4/30/2003 5:47:26 PM
guinea13
Status: offline
Will a 2 oz. tank. I will only be able to fly for about 30 sec. unless I put a very small motor. Any idea what size motor to use?
You bet your a#* I will fly the snot out of it.
       Post #: 54
My first SPAD - checking to see if design will work - 4/30/2003 5:54:44 PM
rchawaii
Status: offline
Don't know, don't fly anything that small :S
an .061 I'm told. I have nothing under .25 right now-and recently got those, b4 that nothing under .40
       Post #: 55
My first SPAD - checking to see if design will work - 4/30/2003 7:51:52 PM
ErnieR
Status: offline
I stand corrected Guinea13. I'm sorry to hear of your crash but at least you didn't blow up your fuel tank in the nose-in. Just think of how much knowledge you gained from building this Spad. Your next one ought to be excellent!!!
I used to fly Funbats and they came with 2 ounce fuel tanks for the recommended .15 size engine. You get about 5-6 minutes of flight on that size tank and engine.
       Post #: 56
My first SPAD - checking to see if design will work - 4/30/2003 7:58:56 PM
guinea13
Status: offline
This plane is not out of comission yet. Needs minor work to put it back in the air. But thanks.
       Post #: 57
My first SPAD - checking to see if design will work - 4/30/2003 10:08:31 PM
RSands
Status: offline
A motor 1 ft. into clay sounds like a very high speed dive. If the elevator stopped working, it may have been from flex? I use popsicle sticks on either side of the coro, and bolt the control horn through them. The control surface works no matter what the speed then. Just a thought. Glad to hear it flies! Feels great to build from scratch doesn't it?
       Post #: 58
Cool Stickers - 4/30/2003 10:09:31 PM
Jagdgeschwader 26
Status: offline
I like the cool stickers: "Optical Fiber Raceway." Is that near Talledega?
Nice SPAD too...looks like it'll overcome the gravitational force nicely.
JG26
AMA 22336
       Post #: 59
My first SPAD - checking to see if design will work - 4/30/2003 10:13:48 PM
guinea13
Status: offline
Ha Ha Ha, Your really funny. No, Really
< Message edited by guinea13 -- Apr 30 2003 7:13PM >
       Post #: 60
My first SPAD - checking to see if design will work - 5/1/2003 1:36:41 AM
rchawaii
Status: offline
As far as control horns, making them the full width of the working control surface area (Ron/elevatr) helps alot in stiffening them up!
       Post #: 61
My first SPAD - checking to see if design will work - 5/1/2003 1:45:55 AM
guinea13
Status: offline
Don't understand? How do you make a control horn the full width of the working control surface. Would that add alot of weight?
       Post #: 62
My first SPAD - checking to see if design will work - 5/1/2003 1:51:01 AM
rchawaii
Status: offline
NO you cut a pvc control horn aboue 1 1/2 oinches long, whatever your surface width is. I'll ssee if I can find a pic.
       Post #: 63
My first SPAD - checking to see if design will work - 5/1/2003 1:52:12 AM
guinea13
Status: offline
oh, width. I was thinking length. I was wondering why you want to do that.
       Post #: 64
My first SPAD - checking to see if design will work - 5/1/2003 1:53:25 AM
guinea13
Status: offline
Don't you want to keep the horn part itself over the bending point to help with bending. I read an article that said you should keep the part where the pushrod connects just over the bending edge on the elev, ailer, etc...
< Message edited by guinea13 -- Apr 30 2003 8:58PM >
       Post #: 65
My first SPAD - checking to see if design will work - 5/1/2003 2:00:10 AM
rchawaii
