pimmnz
Joined: 11/9/2005 From: Auckland, NEW ZEALAND Status: offline
The design changes will depend on what you want to do with the model. If all you want is 'Radio Assist Free Flight' then the minimum changes will be adding a rudder and a new, longer and tapered ply wing brace. If you want a sport R/C then you will need to add rudder, elevator and motor control, with possibly a reduction in dihedral, but definitely a reduction in incidence difference between the wing and tailplane to 1~2 degrees, probably 'proper' symmetric tail sections, if only for strength and rigidity requirements, less downthrust, with this high wing model 2~3 degrees should be enough, and certainly considerably better spars and braces in the wing, with stronger strutting, than the F/F version, just to handle the increased speeds and loadings introduced with the addition of the elevator. I would also look closely at the U/C and use some light spongy wheels, at least. There are two schools of thought here, either re-design as a sport radio type of U/C, or leave it basically similar with the ability to bend it all back to shape after a nasty landing. Of course, the lighter you do this stuff, the less damage any arrival will do, and the less modifying you need to do. Evan, WB #12.
