Extra 260 with DA50
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> Extra 260 with DA50
Page: [1]
Login
Extra 260 with DA50 - 2/23/2008 12:52:01 PM
simon 3d
Status: offline
Hi guys, i have a 30% 260 with a DA-50, first flew the plane last weekend and think its fantastic, i have one issue with it and wondered if anyone else is having the same problem,it seems that my DA is not happy in the cowl, the carburation seems to change very slightly at the bottom end? like the cowl is pressurising??
Any help would be great
Cheers
Simon
_____________________________
IF you have to ask,it wasn't low enough...!!!
       Post #: 1
RE: Extra 260 with DA50 - 3/5/2008 12:37:24 AM
Mark Dennis
Status: offline
Hmm, Is the carb able to breath, or is it just up against the fire wall? I'd try giving DA a call and seeing what they have to say since that does not usually happen.
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to simon 3d)
       Post #: 2
RE: Extra 260 with DA50 - 4/15/2008 3:16:35 AM
robertp17
Status: offline
I am running the da in mine with no problems like that however I was having the exact same problem you described with it last year and sent it back to da because to put it nicely it ran like sh@t. I could not ask for a better running engine now.
(in reply to Mark Dennis)
       Post #: 3
RE: Extra 260 with DA50 - 4/15/2008 8:43:49 PM
simon 3d
Status: offline
Its all sorted thanks chaps it turned out to be the fault of the canister holder in the pipe tunnel.....it was blocking the whole tunnel and trapping all the hot air.....the carb on the da sits directly above the tunnel entrance,and was sucking hot air ....i noticed a vast difference in needle settings when the aircraft was inverted,when the aircraft was upside down the hot air was escaping,and the engine was drawing on cold air ,thus changing the mixture...problem solved
Cheers
Simon
(in reply to robertp17)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
