RE: JMGlasscraft Penetrator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: JMGlasscraft Penetrator Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: JMGlasscraft Penetrator - 3/31/2008 4:21:28 AM
RocketRob
Status: offline
Nice planes Dave.
The micro Estrelita is 4.5 ozs wet
maybe it was a 250 pack I had to get against the firewall
dymond 4.7 servos
berg 4
the little ones are just cute
very nice graphics on your penetrator
(in reply to DeviousDave)
       Post #: 51
RE: JMGlasscraft Penetrator - 3/31/2008 4:26:04 AM
DeviousDave
Status: offline
Wow, you should be proud of 4.5 oz.... That's pretty darn good!
(graphics came from a British Motorcycle magazine.... )
(in reply to RocketRob)
       Post #: 52
RE: JMGlasscraft Penetrator - 3/31/2008 4:27:30 AM
RocketRob
Status: offline
not to be overshadowed by the Micro Estrelita maiden, I got the Penetrator out with a new 6x5 prop.
Now we're getting down to business.
Put pizza cutter wheels on short wing brackets, I can land without tearing up my airfoil
       Post #: 53
RE: JMGlasscraft Penetrator - 4/1/2008 1:15:31 AM
DeviousDave
Status: offline
Sorry I missed seeing that go....
       Post #: 54
RE: JMGlasscraft Penetrator - 4/1/2008 7:42:42 PM
hkbii
Status: online
Howdie gents, I was looking at the pics and though I'd throw this out there. If you bring the push rod closer to the servo (move it in on the horn) untell the servo is at full throw when the control serfase is at its high rate. Then cut off all th arms that are not being used, this is weight thats behind the c.g. The lower power the servo will need to do the same job will extend the battry time. and it should help to take out some of the over rotating. Nice little pane.
       Post #: 55
RE: JMGlasscraft Penetrator - 4/5/2008 9:37:46 PM
RocketRob
Status: offline
Good call, not like I need the throw either
I only fly on low rates even today in the wind - lets just say there were whitecaps on the bay driving home, crossing the bridge back into the city.
3 more flights to the micro estrelita for a total of 6
another penetrator 6x5 flight - one flight a day is enough right now
both had screaming down wind legs the .010 really unwinding
need to start whitteling down a 7x6 for the penetrator and bumping up the nitro on the littlest cox
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by RocketRob -- 4/6/2008 5:32:54 AM >
(in reply to hkbii)
       Post #: 56
RE: JMGlasscraft Penetrator - 4/6/2008 7:52:08 PM
turbotodd
Status: offline
Rob,
Both the Estralita and Penetrator were a big hit at the field yesterday. I have to get one! I am thinking Penetrator on electric power because I have some power systems which should work well. What is the wing span? and AUW with the wheels?
Todd
       Post #: 57
RE: JMGlasscraft Penetrator - 4/6/2008 7:53:46 PM
chevy43
Status: offline
I'm glad I got you that engine. It is going to great use!! I really hope to see that thing fly when I can get some time........
       Post #: 58
RE: JMGlasscraft Penetrator - 4/7/2008 1:56:22 AM
RocketRob
Status: offline
Todd,
carbon Hacker B40 (see first post )
or a lehner 1530 swinging a 5.2x5.2
the micro is 4.5ozs (flying weight) without landing gear
Chevy,
I'm liable to wear it out before I get to fly with you - next weekend after the Meca Collecto
(in reply to chevy43)
       Post #: 59
RE: JMGlasscraft Penetrator - 4/7/2008 1:34:26 PM
RocketRob
Status: offline
Todd,
What about a pee wee Penetrator with a razor rz350-400-microheli v2 on 3s?
Hey Dave, back from Toledo, can you make time to maiden your pee wee penetrator?
       Post #: 60
RE: JMGlasscraft Penetrator - 4/7/2008 10:31:54 PM
DeviousDave
Status: offline
quote:
ORIGINAL: RocketRob
Todd,
Was supposed to fly on Sunday, but John had Greek Easter to do with Family. If I don't go up north to my property next weekend, I'll git 'er done then. Really wanted to fly this weekend.... Of course 200 miles worth of riding after a long winter wasn't too bad either! It was perfect flying weather this weekend!
       Post #: 61
RE: JMGlasscraft Penetrator - 4/10/2008 3:33:38 PM
turbotodd
Status: offline
Rob, I spoke w Jim yesterday. I would like one of each! Its easier to make a good decision that way! I was thinking Penetrator. Now I am thinking maybe a micro Estralita. I have a park 2 blocks away with a large grass field. Now I'll be more motivated to take the dog for a walk over there after work....Multitasking!!! The Medusa 12mm motor has a 1.5 mm shaft. I need to find a lightweight spinner for it. What is the dia. of the fire wall? I already researched and found the servos you recommended. Todd
       Post #: 62
RE: JMGlasscraft Penetrator - 4/10/2008 11:23:36 PM
DeviousDave
Status: offline
You are pretty much on your own for the spinner.. It's a DIY proposition because of the size of the airplane. Back when we first converted these little guys we were using Hobbico FlyZone props that came with a spinner. We ran these on GWS fan motors on 6 cells but they had to be cut down from a 5-3 to a 3" toothpick. With the Medusa you are pretty much stick with making your own. If I ever get dug out of projects, I'll whip up a compression mold and make a few extras.
FYI, the Straight Dope on the Medusa motor is 2S LiPoly with a GWS 3-3 prop cut down to 2.75 and swept back from root to tip and put a new LE on it. It's easy to do evenly with a set of calipers-you use them to scribe/scratch stations from the shaft hole to the blades, then make one blade the the profile you like, then sand the other side so that the stations are the same. Sand, and Voila! Instant custom prop!
(in reply to turbotodd)
       Post #: 63
RE: JMGlasscraft Penetrator - 4/11/2008 2:15:48 AM
turbotodd
Status: offline
Dave,
I ordered 2 of them. I talked my friend into one too. Mini pylon racing @ the park! They will have the new wing. Jim called it a Yellow Jacket. He mentioned painting his yellow/black. Thanks for the low down on the prop. I suppose the Medusa will draw too much current at 3". I picked up the motor, props, and servos today. My local shop had JR's w/11oz. torq. @ 6 grams. I thought this would work well.
A press on spinner would add to the scale look! Its time to play the waiting game now. Todd
       Post #: 64
