DeviousDave
quote:
ORIGINAL: turbotodd Dave, 3 to 1 shaped as a triangle in the factory location. I will check motor temp right after landing through the cowl opening. Once wing is off I'll check the back side. By the way I was impressed with the centering capabilities of the 6g high speed JR servo. I don't recall the part number. I think John said he was going to try them out as well as the Hitec hs45. Is the PeeWee Penetrator much draggier then the Yellow Jacket? I love the way yours looks! John mentioned that it runs on the same Medusa set-up. Great Minds think alike RE: airflow management.. Are you by chance talking about the JR241's? I've only ever used them on 400 racers, and they do indeed work well. For micro stuff, I tend to stick to what I know works well, the HS50. There are probably quite a few great smaller servos these days, I just don't have as much interaction with the electric micro guys as has been the case in the last year or two. At the time anything smaller, and just about everything under 9 grams and made in China didn't center well. Do report back on the servo type you are using! The PWP shouldn't be a whole lot draggier than the MicroShark based airplanes (i.e. Estrellita, Yellow Jacket etc.) as it's just scaled up. The PWP does have a longer tail moment, and I like the way it flies better. I'd like to fly one with a really hot motor, glow or electric as I've only ever seen the PWP fly with 2S and a 4000KV Feigao and with my G-Mark .03. Neither will pull the skim off warm milk, but they can get out of their own way and offer non-park flier performance in a sleek package. Here's a qualifier though-the electric PWP had one of John's built up wings, and my G-Mark powered one uses his same airfoil-at my prodding (just happened to have the cores laying around and they fit the tiny wing saddles) every one of his planes was faster with an RG14 wing without a penalty in other areas of performance. John's airfoil is almost a match on top for the RG14, but the bottom is fatter. Sooo..... did you take your Wife to the field for Mothers day to show her the new 3S battery pack you bought her?
