Hyperion EOS0610i Duo
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MaxAmps Support >> Hyperion EOS0610i Duo
Page: [1]
Login
Hyperion EOS0610i Duo - 2/24/2008 12:12:39 AM
rasjax
Status: offline
I just picked up the Hyperion EOS0610i Duo, but just noticed it doesnt have an AC plug. What is the best way to rig this up to a AC wall outlet?? I was looking at one of these, but not sure if it will work.
http://www.grandrc.com/inc/sdetail/79685
Any advice or suggestions would be appreciated.
       Post #: 1
RE: Hyperion EOS0610i Duo - 2/24/2008 12:22:23 AM
JAM MaxAmps
Status: offline
Your gonna want a power supply that will do 11 to 15 volts and around 360 watts or more to get the best performance out of it.
Jason
_____________________________
Jason
MaxAmps Marketing Manager/Tech Support
(in reply to rasjax)
       Post #: 2
RE: Hyperion EOS0610i Duo - 2/24/2008 12:58:45 AM
bobferguson
Status: offline
I have a Pro Peak 20 Amp Single Output Power Supply and are very happy with it. It is only $59 but does have the extra output jacks which would be nice to have and does not have a current display. I been thinking of adding a second set of output jacks to mine.
(in reply to JAM MaxAmps)
       Post #: 3
RE: Hyperion EOS0610i Duo - 2/24/2008 1:36:48 AM
rasjax
Status: offline
quote:
ORIGINAL: JAM MaxAmps
Jason
The Duo specs say it can do up to 8 amps at 44.4 volts. With a 10A 180W limit per power port. So if that is the case will a 12V DC inverter actually work? ... Or do I need an inverter that can do at least 44.4V and 10A.
That other one I linked before maxes out at like 8A, and I probably need one that can do at least 10A. So I found this one... You think this should work??
DF 1763 AC TO DC CONVERTER
This unit converts from AC to 13.8V DC Power. Ideal for household transceiver, automobile/mobile equipment, and portable equipment.
Input Voltage: 110V AC or 220V AC
10% Load Regulation
Output Current: 10A
Applies Current Limit Short Circuit protection for DC output.
5% Voltage Regulation
Current Limit Protector for AC Input
One Hour Continuous Working Time
http://www.voltage-converter-transformers.com/heavy-duty-voltage-converter.html
< Message edited by rasjax -- 2/24/2008 1:58:07 AM >
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
