BaldEagel
Joined: 10/12/2005 From: Wychling, Kent, UNITED KINGDOM Status: offline
quote:
ORIGINAL: Magic R/C I have ran the evo 45 before and it is a good engine, but it is very heavy. The motor would be a awesome combo, but it will put you so nose heavy that all your gear pushed back as far it will go will not balance it. The DA 50 is what I run on my 86 and I must say it is awesome. The evo is cheaper by about $70.00 but the extra money spent will save you alot of hassle later. Evo are a Spanish manufacturer and do not make a 45, the MVVS 45 is the same weight as the DA, nearly all QQ Yak's come out tail heavy, Don't know where you get your information from, but its very misleading, My 85" QQ Yak (see above) with an MVVS 58 Pro in it has the batteries on the wing tube, so it is not "so nose heavy" as you suggest. Looking through the forum most people have had to put the batteries either in the cowl or hard up against the firewall. Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
