opjose
MD, USA Status: offline
quote:
ORIGINAL: Evgeny-arm The happiness has terminated. I had so much pleasures from purchase of the plane. I have forgotten disappointments from unsuccessful purchases of models at Nitro Planes. The happiness has terminated when has begun installation of the equipment (look a photo). At pushing through of the extension piece of a cord, it has not gone. Has opened a side panel and to me it became brutally bad. As so it is possible to hate the buyers to scoff at them. It is More at Nitro Planes I shall never buy. It that I now should open all side panel? This is hardly a problem with the plane, and more a problem with an inexperienced builder. You can use a pin to temporarily remove the connector pin inserts, pass the cable through, then place the connector pins back into the socket. This is trivial. You could have also merely resized the circular cutout a bit to avoid having to cut a hole into the wing. This is not a problem.
_____________________________
- Build em'', fly em'', crash em'' and build more.
