Sonic charge error???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> Sonic charge error???
Page: [1]
Login
Sonic charge error??? - 2/25/2008 5:39:39 AM
PwndByMustang
Status: offline
I built 3 3s1p packs out of a Dewalt Pack and bought the sonic charger and balance taps and i wired them all up and none of them charge???? It just gives me a blinking error light?? Soo i built a 2s1p pack and it charged to 7.2v but 1 cell is 3.4v and 1 is 3.8v. I am using a 350w computer power supply at 12v and 15 amps. I know i got the power and the wiring right right but what could the problem be??????
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Sonic charge error??? - 2/28/2008 4:29:01 AM
pedeonyou
Status: offline
I have the same red error light when the 3s1p is attached.
When the battery is attached, the error light turns solid red. I have the balance taps wired correctly according to the developer cell diagram.
The power supply I am using is a Vantec 470w PC power supply 10.8V 28amps.
(in reply to PwndByMustang)
       Post #: 2
RE: Sonic charge error??? - 2/28/2008 5:42:30 AM
PwndByMustang
Status: offline
Do you happen to know what is wrong? cuz a123 hasn't answered any of my emails and i'm not to happy with their lack of technical support.
(in reply to pedeonyou)
       Post #: 3
RE: Sonic charge error??? - 2/28/2008 10:19:26 PM
pedeonyou
Status: offline
It might be the input voltage to the charger. My 12v lead on my power supply actually reads 10.8v for some reason. Check it with your voltmeter. Let me know what you get.
       Post #: 4
RE: Sonic charge error??? - 2/29/2008 1:11:57 AM
PwndByMustang
Status: offline
Its 11.84v with a 10 amp load. So i know its enough.
       Post #: 5
RE: Sonic charge error??? - 3/5/2008 1:42:23 PM
n57tc
Status: offline
I have the Sonic Charger and use a 12 volt car battery. The only time I get the red error light is when the input voltage is below 12.6 volts. After I charge the battery the red light does not come on.
I would try connecting the charger to your car battery to see if you get the error light or not.
       Post #: 6
RE: Sonic charge error??? - 5/9/2008 3:17:15 AM
Strada916
Status: offline
this is because PC power supplies can not provide the correct voltage unless you load the 5V rail. These PSU only regulate the 5V output therefore you need to load the 5 volt output to get the unit tio give you a good 12V at a high current. a resistor of about 0.5 Ohms and about 20W will do nicely. Once you have done that then see what the loaded voltage is at the PC PSU
(in reply to n57tc)
       Post #: 7
RE: Sonic charge error??? - 5/9/2008 3:25:07 AM
PwndByMustang
Status: offline
Actually i sent it in and finally got it back about a week ago and now it works perfect when hooked up to my psu.
(in reply to Strada916)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
