RE: roll cage    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: roll cage
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: roll cage - 2/27/2008 5:44 AM
jumpanddrop
Score: 100
Last Login: 8/25/2008
Status: offline
quote:
ORIGINAL: taylor152806
watch kuppler vid. he is nutz. and a roll cage is a must 3/16 solid alum rod. http://durafix.com/
check this out so easy to use just listen to the instrutions!!!!
let me know how it works. lol that spool gu was ALOT of money. w/e its so fast and i can weld realy thik aluminem with it . time to make a custom chasis with the plasma
Hide Signatures
(in reply to taylor152806)
       Post #: 26
RE: roll cage - 2/27/2008 6:25 AM
Redharris
Score: 105
Last Login: 12/9/2012
Status: offline
quote:
ORIGINAL: kuppler
quote:
ORIGINAL: jumpanddrop
fisrt of all whats the perpose of a roll cage. im thinking of a roll bar maybe. if the cage is a good idea i might just weld an alumenum one up
lol.. if you bash like i do... you might want a Roll cage... im looking into it as well... hahahha
I dont think a Roll Cage will save your Spur Gear, Bro
_____________________________
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
(in reply to kuppler)
       Post #: 27
RE: roll cage - 2/27/2008 6:28 AM
ranger4x4
Score: 103
Last Login: 9/17/2010
Status: offline
quick question . would it be stronger to have tubing bent and not welded at the corners? those would be the weak points on any roll cage i think. and if your the evil kinevil of nitro rc ahem...(kuppler)...ahem, you would need all the strength you can get out of a roll cage. just a thought is all it is.
mxt 2-s mega e mt10 viper
Hide Signatures
(in reply to jumpanddrop)
       Post #: 28
RE: roll cage - 2/27/2008 6:30 AM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
You can add cross member bars in the bends to make it stronger
Hide Signatures
(in reply to ranger4x4)
       Post #: 29
RE: roll cage - 2/27/2008 6:31 AM
Redharris
Score: 105
Status: offline
I think a Roll Cage would be a very Cool Custom Item. Can you make em Light enuff?
Also, I think a lot of people would buy a Custom made aluminun Bumper too, if you designed it to bolt up Cleanly.
Hide Signatures
       Post #: 30
RE: roll cage - 2/27/2008 6:39 AM
jumpanddrop
Score: 100
Status: offline
ya it would be cool to play around with. i have all the tools, i just need to pick up some aluminem and play around. its not cheap tho .
Hide Signatures
(in reply to Redharris)
       Post #: 31
RE: roll cage - 2/27/2008 6:42 AM
ranger4x4
Score: 103
Status: offline
i want to make a set of these for my volcano to go with a roll cage for it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 32
RE: roll cage - 2/27/2008 6:44 AM
Macanan
Score: 100
Status: offline
quote:
ORIGINAL: ranger4x4
Check this out http://cgi.ebay.com/Heavy-duty-Front-Bumper-for-Tamiya-F350-High-Lift_W0QQitemZ120213878449QQihZ002QQcategoryZ44028QQcmdZViewItemQQ_trksidZp1742.m153.l1262
or this one
http://cgi.ebay.com/Black-Front-Bumper-for-Tamiya-F350-High-Lift-Crawler_W0QQitemZ110217228346QQihZ001QQcategoryZ44028QQcmdZViewItemQQ_trksidZp1742.m153.l1262
< Message edited by Macanan -- 2/27/2008 6:48 AM >
Hide Signatures
       Post #: 33
RE: roll cage - 2/27/2008 6:59 AM
webbl19
Score: 100
Last Login: 9/4/2009
Status: offline
quote:
ORIGINAL: Redharris
I think if you made it out of aluminum it wouldnt be that heavy. The aluminum would probably bend on big impacts though so that would be a bummer.
Exceed Razor, RedCat Tsumani and wanna be Volcano
Hide Signatures
       Post #: 34
RE: roll cage - 2/27/2008 7:07 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
actually with bends in the right spots aluim is very durable....would take some time to design one that is not only light, but durable as well...aluim will however crack in sharp bends...so if I was to build one I myself would weld any sharp bends
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to webbl19)
       Post #: 35
RE: roll cage - 2/27/2008 7:12 AM
webbl19
Score: 100
Status: offline
i am thinking something like this would work, its steel so it would be a bit heavier and duriable and the cage is not going to be that big so i dont think it would be more then a pound or two. they got 1/4 also i would have to see in person how they look.
http://hardware.hardwarestore.com/27-592-square-and-round-stocks/welded-steel-rod-154476.aspx
Hide Signatures
(in reply to firebird78)
       Post #: 36
RE: roll cage - 2/27/2008 8:00 AM
ranger4x4
Score: 103
Status: offline
i was thinking of using brake line tubing. it's easy to make bends with. and easy to cut out any sections that need to be replaced after a big impact. all the force of a hard landing on that cage has to somewhere and chances are it just might bend the chassis plate. i don't know about you guys but i would rather change a piece of tubing than the bottom plate. whats your opinion on the tubing? do you guys think it might work?
Hide Signatures
       Post #: 37
RE: roll cage - 2/27/2008 8:16 AM
webbl19
Score: 100
Status: offline
brake lines would work but they are hollow so they would bend pretty easy, probably just a few cartwheels would make it bend, but i dont know, be easy to make fixes though.
what if you took like cage under the chassis also so that way it will keep the chassis strong. im thinking about a cage that fits around the whole truck.
Hide Signatures
       Post #: 38
RE: roll cage - 2/27/2008 8:25 AM
kuppler
Score: 100
Last Login: 11/8/2011
Status: offline
quote:
ORIGINAL: webbl19
LOL... and just the wheels sticking out ???
OFFICIAL HIMOTO RACING SUPPORT http://himotoracing.com, http://himotoracingusa.com
Owner of The 805 Hobbies
Hide Signatures
       Post #: 39
RE: roll cage - 2/27/2008 8:47 AM
webbl19
Score: 100
Status: offline
no i am thinking something like this, it is a very rough draft lol
Click for fullsize
Hide Signatures
       Post #: 40
RE: roll cage - 2/27/2008 8:49 AM
kuppler
Score: 100
Status: offline
i c... just to cover the bottom...
Hide Signatures
       Post #: 41
RE: roll cage - 2/27/2008 8:55 AM
webbl19
Score: 100
Status: offline
yeah to keep it from bending. get some type of eyelets or mirror fasteners and weld them to the cage to put screws through the chassis to hold it in. that way it can be taken off easy. i have the idea in my head. i will see if i can come up with something.
Hide Signatures
       Post #: 42
RE: roll cage - 2/27/2008 8:57 AM
kuppler
Score: 100
Status: offline
sweet.... Make one.. take some pics.. and then i can test it out for you.... hehehehe
Hide Signatures
       Post #: 43
RE: roll cage - 2/27/2008 9:00 AM
webbl19
Score: 100
Status: offline
or how about i make it and send you the specs so you can make your own...
Hide Signatures
       Post #: 44
RE: roll cage - 2/27/2008 9:12 AM
kuppler
Score: 100
Status: offline
quote:
ORIGINAL: webbl19
Ok,... that sounds GOOD........
Hide Signatures
       Post #: 45
RE: roll cage - 2/27/2008 10:24 AM
Redharris
Score: 105
Status: offline
you might try incorporating the roll cage into the Aluminum Shock towers. what I mean is,ya might design the roll cage in 2 or 3 pieces that have anchor points on the Shock towers And the chasis. Multiple anchor points might add rigidity, and make it easier to work on the truck when you DO break something.
Hide Signatures
       Post #: 46
RE: roll cage - 2/27/2008 10:28 AM
webbl19
Score: 100
Status: offline
i was thinking about going over the shock towers and maybe integrating a bumper onto the cage so you can take off the plastic one.
Hide Signatures
       Post #: 47
RE: roll cage - 2/27/2008 5:33 PM
ranger4x4
Score: 103
Status: offline
why not do the roll cage kind of like they use in nascar. but make it so it can be easily attached to the bottom plate. by having tabs added to the bottom of each post that are flat with a hole drilled so it can be bolted to the truck. one whole piece that covers basicaly the whole truck with maybe a 1/4 inch under the body with just the body posts coming through. or make it a exocage with the body attached under the roll cage. just a couple more ideas to throw out there. then you can add what ever style bumper you like to it.
Hide Signatures
       Post #: 48
RE: roll cage - 3/1/2008 6:45 AM
taylor152806
Score: 100
Last Login: 6/16/2008
Status: offline
so i got the mock-up done made it from wood rods. betwen work school and the wife just run out of time. lol. and snow. hope to start building in the am. will post pics very soon. just not sure how.
Hide Signatures
       Post #: 49
RE: roll cage - 3/2/2008 3:38 AM
taylor152806
Score: 100
Status: offline
well 3hrs into. its ruff but i will get it... lookin great so far
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
