BT-64EIS no spark
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Fuji-Imvac Engines Support >> BT-64EIS no spark
Page: [1]
Login
BT-64EIS no spark - 2/26/2008 12:49:29 AM
dh7583
Status: offline
I have a Fuji BT-64EIS that has no spark. I was wondering if there were any way to check the hall effect sensor and the EIS module with a digital multimeter such as a Fluke or a Fieldpeice to determine which may be at fault. There is no discharge what so ever. I also have the capability of checking capacitors up to 380 MFD and wonder if the capacitor alone can be checked and if so what is it's value.
       Post #: 1
RE: BT-64EIS no spark - 2/27/2008 4:12:28 PM
Bax
Status: offline
If you have the electronic ignition system and you get no spark, then either the sensor is bad or the ignition unit is bad. The only way to check the sensor would be with an oscilloscope that can "read and hold". The voltage spike is too fleeting to be picked up on a meter.
Usually, it's the ignition controller electronics that have gone out when you get no spark. It will likely need to be replaced.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to dh7583)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.719RCU1
