Servo replacement for HS225 in Sig SE?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Servo replacement for HS225 in Sig SE?
Page: [1]
Login
Servo replacement for HS225 in Sig SE? - 4/22/2003 8:31:11 PM
jharkin
Status: offline
I have a Sig Somethin Extra that I am using HS-225BB's on the ailerons and rudder. I made this choice based on the specs but from reading the forum it sounds like these are too small to stand up to the loads in this type of plane. I have the throws set low (about 1/2 of spec) while I get used to it, but am concerned that once I open it up the 225s are likely to fail.
So my questions is should I replace the 225s with something beefier and if so whats a good Hitec choice? FYI, my skill level is probably intermediate (2yr flying, 4 planes).
Thanks!
       Post #: 1
Servo replacement for HS225 in Sig SE? - 4/22/2003 9:07:43 PM
MikeMayberry
Status: online
The nylon gears in the mini servos are not as strong as the standards and there have been a couple post of people stripping them when flying hard. You might want to consider replacing the nylon gears with metal to be on the safe side.
Mike.
(in reply to jharkin)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
