RE: CA Models Pass-Port Build
Tower Hobbies
Logged in as Guest
  Printable Version
ZN Line twister
Seller:  danno-RCU
Details:   $1,100.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> RE: CA Models Pass-Port Build
Page: <<   < prev  1 2 3 [4]
Login
RE: CA Models Pass-Port Build - 3/14/2008 8:23:47 PM
Passport1
Status: offline
quote:
ORIGINAL: Ryan Smith
Awesome, thanks for the pictures Todd. Have you flown the airplane any more? Any additional comments?
Today I finally was able to get out and test fly my new Passport. I ended up going with Narukes recomendation as far as the ail servos and that is the low profile digital 9154 wing servo. They fit the openings in the wing perfectly and seem to be more then enough power and speed. I set up a basic program with no p-mixs and went for it. It was very much like the prototype and didn't really need any trimming to speak of. I am going to fly in calm air in the morning, and then I will be able to really fine tune it. I will get pictures as well as more trimming info. up just as soon as I get a break from the wind.
Chip
(in reply to Ryan Smith)
       Post #: 76
RE: CA Models Pass-Port Build - 3/14/2008 10:05:36 PM
elan120
Status: online
Chip, Todd,
The plane looks great. Looking forward to more flight reports.
Is there any weight information available on the standard kit and do you think it will make the weight going electric also? Meanwhile, what method was used to attach stab to fuselage?
Thank you,
Kevin
(in reply to Passport1)
       Post #: 77
RE: CA Models Pass-Port Build - 3/15/2008 2:23:04 PM
Passport1
Status: offline
quote:
ORIGINAL: elan120
Chip, Todd,
Thank you,
Kevin
Our planes both came out right at 4950 grams without doing anything other then just a normal assembly. All in all weight should be no issue for these planes even with some extras the design incorporates.
As for the Stab attachment, its really simple. Since the adjusters are mounted in the stab halves rather then the fuse, we use those to clamp onto the forward antirotation pin (Basically a set screw top and bottom) Then to remove the stabs pick either the top or bottom and loosen that set screw 1 turn. Its really better to secure at the leading edge of the stab versus the tube location anyway because you can keep a tighter fit up to the fuse.
I will get a picture up before the weekend is out to help visualize this a little better.
Chip
(in reply to elan120)
       Post #: 78
RE: CA Models Pass-Port Build - 3/16/2008 5:31:09 AM
elan120
Status: online
Thank you for the input Chip, and nice to know the standard kit can make the weight also. Meanwhile, looking forward to the picture for the stab attachment.
Kevin
       Post #: 79
RE: CA Models Pass-Port Build - 3/17/2008 4:59:20 PM
toddblose
Status: offline
Kevin,
Here are some pic's on how we hold the stab on. Like Chip said the stab adjuster has a screw on top and bottom. Once the stab is set we tighten down the screws onto the front rod that goes through the fuse and your done.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
http://toddblose.homestead.com
Team Futaba,FlightPower,Hacker,CA Models,Hobbico, PowerMaster,HydeMounts,ModelGlasses
       Post #: 80
RE: CA Models Pass-Port Build - 3/17/2008 6:07:00 PM
elan120
Status: online
Todd,
Based on Chip's explanation, I had pretty good ideas how it might work, but the pictures sure makes it even easier to comprehend the attachment method and it looks like a very clever idea for sure.
Thank you,
Kevin
(in reply to toddblose)
       Post #: 81
RE: CA Models Pass-Port Build - 3/26/2008 5:42:03 PM
Ricardo M.
Status: offline
Any flight report?
       Post #: 82
RE: CA Models Pass-Port Build - 3/26/2008 11:11:04 PM
toddblose
Status: offline
Chip has more time on his Pass-Port than I do so if he gets a chance I hope he will post the results, he has just left to go overseas
so not sure he will see this post. I only have 6 flights due to the weather here but I can say I am very happy so far. The mix on the plane is about 5% rudder to elev and it looks like that will be all the mixing I will do. The plane has a very constant speed both up and down, and has blown me away on how easy it does all rolling maneuvers. I will let you know as I get more time on it.
(in reply to Ricardo M.)
       Post #: 83
RE: CA Models Pass-Port Build - 4/9/2008 7:32:46 PM
TeamFutaba02
Status: offline
Hey everyone,
I was down in Tucson with chip a couple weeks ago and flew his passport. This plane is by far the best pattern plane I have ever flown. Rolls like Todd said are incredible. It feels so solid. This was also the first electric pattern plane I have flown and the electric has a much more consistant feel to it. The power is incredible and very smooth. Rolling loops are a breeze and require only 1/4 to 1/3 rudder with power out of the bottom.
I picked up my passport while I was down there and am assembling it now. I will keep everyone updated on it as well.
Trent
T-Byrd
~Team Futaba~ ~Desert Aircraft~ ~Team Airwild~
       Post #: 84
RE: CA Models Pass-Port Build - 4/9/2008 8:46:35 PM
shannah
Status: offline
Hi Trent,
Are you going to build yours e-powered? Which version of the plane did you get (arc std, deluxe, or kit). I'm thinking about getting one of these things for myself.
Steve Hannah
(in reply to TeamFutaba02)
       Post #: 85
RE: CA Models Pass-Port Build - 4/9/2008 10:03:45 PM
TeamFutaba02
Status: offline
Hey Steve!
I got the ARF dlx I guess. It came with everything and is the same scheme as Chips. Ive got everything hinged, aileron servos in, working on the elevator and rudder servos now. Mine will be epowered as well.
You wont be dissapointed at all! This thing is incredible. Ill have mine flying by the end of the month hopefully sooner. Ill keep you updated with pics and flying reviews.
Trent
T-Byrd
(in reply to shannah)
       Post #: 86
RE: CA Models Pass-Port Build - 4/9/2008 10:34:34 PM
shannah
Status: offline
Sounds cool,
Maybe I'll have to sell my big Dalton 260 after all. Need to make room for this. I haven't flown much IMAC since I started flying FAI again.
       Post #: 87
RE: CA Models Pass-Port Build - 5/16/2008 5:31:28 AM
Patterndude1
Status: offline
Well I was lucky that I called to get the last pass port that Net Box has just in time, "it should be arriving today" . They are backordered now, but he should be getting a new shipment of them pretty soon.
Matthew Liprie
Hacker motors
Flight Power Batteries
Thunder Power Batteries
JR
< Message edited by Patterndude1 -- 5/16/2008 5:33:53 AM >
       Post #: 88
RE: CA Models Pass-Port Build - 9/11/2008 7:59:06 AM
saflyer
Status: offline
Can someone post some of the wing and stab setups please. Angles and some more pictures.
(in reply to Patterndude1)
       Post #: 89
Jump to:
