Campgems
CA, USA Status: online
When you finish, you will be happy you didn't get the bARF. I've built two of the 4*60 and they are one of the fasest builds I've ever done. Every thing fits and you basicly put the section together, then glue it. If you have a straight building board, you are good to go. Just a word of advise on it. Make sure you follow the instructions to the T. Don't build ahead of the step you are doing, even if it seems the next logical thing to do. There were a couple places that you could get in trouble by doing this, one was the lower wing center sheating. Follow the instructions. One more piece of advise is to check the build threads on both the 4*60 and 4*40 for recomended beef up areas. IE the fuse just behind the wing and the Landing gear mount. Oh yes, one more thing, add a second outboard hinge on the ailerons in one rib bay from the tip. This is incase you later decide to clip the wings for a little better performance. Have fun building. I know you will have fun flying it. Don
