mred33
Joined: 5/12/2006 From: Glenwood, GA, USA Status: offline
I think in the long run you will be better off with one radio to contend with. I looked up your manual and it is not hard to program your dual rates. Go to page 44 and start reading there. It won't hurt to play with the programming a little with the book in your hand to help you. I would set it up with a single switch to turn the dual rates on and off. Makes it easy to start with. I would set your low rate to around 50% to 75% to start with. The low rates makes it easier to fly the plane the first few times as it doesn't respond quite as fast as with full rates. On the Diff. I would go about 10% or somewhere around there. After you fly it the first couple of times you can find a setting you like, but don't put to much in there to start with. Diff. makes the control softer around center so that it does not roll real fast when you give it a small control command. You still have full control movement, it just doesn't move as much around center with Diff. and it makes it a little easier to control some planes. You may find you don't need any at all, but it won't hurt to try it. You can set all three control surfaces to dual rate and Diff. I don't like Diff much as I don't fly 3D planes and don't need it that much. However, dual rates are nice and I use them all the time. The best way to play around with this is to have the plane set up with everything turned on so you can see what is going on. Don't try to program the transmitter just by itself without the receiver on and the servos working. That is the last thing you do after you get everything set up. I have my transmitter programmed for triple rates because I like it that way. You can't do that on yours, but the dual rates are really nice. If you have any questions let me know and I'll try and answer them. Good luck with the programming. Ed
_____________________________
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
