dapam03
Joined: 1/8/2008 From: Morrisburg, ON, CANADA Status: offline
Cbenko, If you glue the inside end rib holding the guage against it the way i'm showing it on my last post, it should work out. Check it in about 3 places, because you could have it on on one end of the rib and off at the other end. It tilts in at the top about 2 degrees. When you cut the slot out for your dihedral brace, check it again, in case it changes. If you wick in with thin ca either side of the spars, it shouldn't change. Hope that helps answer your question
