iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
Looking at your landing gear plate I hope that you did not fill the bolt holes with epoxy. You usually want the bolts to go through the blind nuts. As far as the motor mount don't sweat it if the hole is just a bit to large it should be fine. Thinned 5 min epoxy or dope is what I use for fuel proofing, longer drying epoxy adds to much weight were it soaks into the wood more. Sounds Like you are making good progress on your build, and as suggested you will find wood glue, despite its longer cure time will give you the best results for structural strength. Epoxy is the only thing that will give you a stronger bond but it is heavier than the glue. I only use CA to tack parts or for the leading edge joints were I need a fast bond before bending, other than that I use wood glue, Sigment, or epoxy for my builds. A lot of guys swear by elmers white glue but I am not sure that it is fuel proof. After finishing with your trainer a .46 would be a good match for a .40 size midstar or 4 star depending on where you want to go with your next plane, midsar is a bit tamer than a 4 star, but both fly well with a .46. You will find that the best thing to do to increase the performance of any build you do is to keep it light as possible. That means using as little glue as possible and wiping of any excess you can, you will find the scrap balsa in your kit makes good tools to get in and remove excess glue while you are building. I would suggest that you take the time to go to: http://www.airfieldmodels.com He has many good tip for those who want to build a nice flying model, not to mention to look at some very nice airplanes... edit to add: One tip for setting blind nuts... Tap them a bit to set them into the wood before you draw them in with the bolt, if you strip them sometimes you can tap them with the next largest size tap, if they have enough meat but it is usually best to have a few spares and just replace them, just in case, you can find them at most hardware stores cheaper than you local hobby shop. Often I set my blind nuts with a bolt and washer before I do the final bolt down of mounts, and always make sure to keep the CA or epoxy if you use it away from the bolt hole unless you have the bolt in, and plan to make whatever you mount non removable.
< Message edited by iron eagel -- 3/10/2008 4:55:05 PM >
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
