mred33
Joined: 5/12/2006 From: Glenwood, GA, USA Status: online
I always solder a short connector to the throttle end of the wire and use a ball joint connector on it, but you can use a regular nylon connector if you want. Solder the connector on first and then put the ball joint or what ever you are using on after. You should be using nylon on the engine connection because of noise, unless you are on 2.4GHz. If you solder with the connector on, you will melt it. The servo end you can just tin it good and use a quick connector on that end. I use a regular connector on most of mine, but either work find. When you solder the connector on, tin the wire and put a peice of solder inside the connector the length of the hole. That will tin the inside while you are soldering them together. I drill a hole in a block of wood to hold the connector and then hold the wire up to it and apply heat. When you get everything hot, the wire should just drop right in. Make sure you don't move it until it cools or you will have a weak solder job. No problem with the epoxy on the fuse sides. I don't do it because I don't like to, but that does not mean you can't. I always get to much glue on and have to wipe some of it up and epoxy cost more then yellow glue. Just because you did something different then I do does not make you wrong, it just means you did something different. I use yellow glue because it is cheaper and lighter, at least the way I glue things together. If you ever do use yellow glue, make sure you bloce it down GOOD and add weight to hold it. If not, you will find out why very shortly why it has to be blocked and weighted down and you won't have to waite for the glue to dry either. About 1 min after you put the glue on it will start to curl up. Sorry about that, I got carried away again. Ed
_____________________________
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
