Simulated Rib Stitching Tape
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Product Announcements & Manufacturer News >> Simulated Rib Stitching Tape
Page: [1]
Login
Simulated Rib Stitching Tape - 4/23/2003 1:02:00 AM
zoomzoooie
Status: offline
*SIMULATED RIB STITCH TAPE*
Simulated Rib Stitching tape is now available in 1/4 scale. Stitch spacing is equal to full scale spacing of 2".
Each package contains four rolls of 2" wide by 36" long double sided Simulated Rib Stitch Tape that will yield 2304" of rib stitch tape cut at 1/8" wide and should be enough to complete most 1/4 scale biplanes up to 100" wingspan.
Other scales and special orders are available on request. 1/5, 1/6 scale and 1/3 scale will soon be available But if you need some now, just place an order.
Application is as easy as cutting to cord length and rib width. Peel back the first backing and apply it to your wing panel.
When you are ready to apply your finishing strip, remove the second backing from the Rib Stitch Tape, which will reveal the Simulated Rib Stitches. The double sided adhesive will help to keep your finishing strip in place. Apply your finishing strips and your project is now ready for your finishing color scheme. If you chose an iron on covering that you will not be painting, that's it! You are done! Stand back and admire that finishing touch of scale detail on your project!
Check out the photos samples using Johnson and Johnson 1/2" medical tape as a finishing strip. It has pinked edges that is close to scale. If you use a filling base coat you can blend the strip in to lessen the detail of the pinked edge if needed. I left it sharp on the samples for photographic purposes. Note that there has been no sanding at this stage.
Email me to find out more about my Simulated Rib Stitching Tape and how to get some:
[email]zoomzoooie@cablerocket.com[/email]
Be sure to put "Simulated Rib Stitch Tape" in subject line.
ZZ
Click to see fullsize image.
Click for fullsize
< Message edited by zoomzoooie -- Apr 22 2003 9:35PM >
       Post #: 1
Simulated Rib Stitching Tape - 4/23/2003 1:04:46 AM
zoomzoooie
Status: offline
Here's another Pic.
This shot shows the tape with and without the backing.
Click for fullsize
(in reply to zoomzoooie)
       Post #: 2
RE: Simulated <span class= - 11/7/2003 7:46:18 AM
zoomzoooie
Status: offline
I have been getting several requests for info relating to "pinking tape".
I would just like to clarify that my scale rib stitch tape does NOT include pinking tape.
I have left this up to the builder because of the many sizes and widths used on various aircraft.
You can get it from Stits.com or make your own. I can give you info on how to make your own if you wish.
ZZ
_____________________________
If it don't have at least two wings, I can't see how it could possibly fly...
       Post #: 3
RE: Simulated Rib Stitching Tape - 2/13/2006 3:05:10 AM
Smith Mini
Status: offline
Could you tell me what size width you would cut your stitching strips.and what widthof tape for 1/2 scale.? I am looking for a finished Bi-plane finished with your stitching. Picture?
       Post #: 4
RE: Simulated Rib Stitching Tape - 2/13/2006 6:24:09 PM
zoomzoooie
Status: offline
Smith Mini,
Stitching widths vary on different aircraft. Usually tho, the stitch width is the same width of the rib, since the stitching wraps around one side of the rib to the other.
The Smith Mini plane used conventional built up ribs of 1/4" square spruce with no cap strips.
A 1/2 scale model would have 1/8" wide stitches.
You can check the website for a few photos and more info: http://home.cablerocket.com/~scaleribstitch/index.htm
Email me at: scaleribstitch@cablerocket.com for more photos.
ZZ
Click for fullsize
Click for fullsize
(in reply to Smith Mini)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
