Low Show
NC, USA Status: offline
I'm using Robart's # 654 off of my deceased TopFlite C-182, you will need to do the following to make it work, find a thinner wheel like a Dave Brown 3" foam ( this will also need to be cut down a little, chuck it on the drill press a sanded about 3/16" off of it ), use a piece a brass tube to increase the O.D. of the strut in the bracket area to 10mm, get a little beefer spring. remove the lower strut and fork from the supplied unit. I heated the lower strut at the very tip enough to break the fork free from the Wheel Pant ( BECAREFUL----GO SLOW !!!!! ), file a slot for the lower scissors to slip thru. This may eam like a lot of work but it to me a total of 20 min. to do this, the product is already on the market so you will not have to wait. Of course you can skip a couple of steps and use the block that comes with the Robo, I just liked the neat little Alum. supplied in the kit. Robart also makes a RoboStrut that could also work but you would need to drill out the Alum. bracket from 10mm to 7/16" and I believe that this may weaken it. Hope this helps, Thanks...Don
