Hanger 9 new Skylane
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> Hanger 9 new Skylane
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Hanger 9 new Skylane - 4/23/2003 2:45:46 AM
drdoom
Status: offline
Does anyone know when the hanger nine giant scale Cessna 182 Skylane will be available?
       Post #: 1
Hanger 9 new Skylane - 4/23/2003 5:02:37 AM
tailskid
Status: offline
Maybe late this month or early next? Sure hope so....I want to see one of those babies fly!
Jerry
_____________________________
# 93 in Club Saito
(in reply to drdoom)
       Post #: 2
Hanger 9 new Skylane - 4/23/2003 11:37:32 PM
SteveD-RCU
Status: offline
I heard mid-MAY...SteveD
       Post #: 3
Hanger 9 new Skylane - 4/24/2003 2:11:30 AM
tailskid
Status: offline
Yep, I called today and that was the answer I got too! Bummer....
Jerry
# 93 in Club Saito
       Post #: 4
shipped - 5/22/2003 11:28:43 PM
drdoom
Status: offline
Mine is beeing shipped today!
wont be here untill after the holliday.
Dennis
       Post #: 5
GOT TWO !!! - 5/23/2003 12:39:27 AM
dmyers0403
Status: offline
Recieved two. One for me and one for my buddy last night 5/21/03
Great looking kit. Will start asap on assembly.
       Post #: 6
Skylane - 5/23/2003 12:56:30 AM
drdoom
Status: offline
Does it come with the scale accessory that is on the horizon web page? also the decal sheet and fuse hatch. listed as accessories on the site.
Dennis
       Post #: 7
Accessories for 182 - 5/23/2003 3:05:12 AM
dmyers0403
Status: offline
Kit included the four fuzzy seats, decal sheet consisting of dash decal and some markings, all other markings are already on plane fuse and stab. Caban hatch cover at top of fuse and antenna mouldings are included.
Inside of caban walls are finished - no exposed framing and a finished floor hatch to cover servo tray below. Finish is a speckled type (matte). Includes a scale shaped dash unit. You can use the instrument decal or make your own.
Cowl blocks are pre-installed with metal blind nuts, cowl is pre-drilled.
Wing tube fit is excellant and rotation pins are installed.
Hope this helps. Ask if you need more - This looks to be a great kit. Finish is very Good.
Combination of fiberglass fuse and wood frame covered in what looks like ultra coat or sim. - very good job, no wrinkles etc. All markings line up.
We got ours at Ultimate RC in Broken Arrow, Oklahoma 918-258-0061 (he has great prices)
       Post #: 8
Hangar 9 new Skylane - 5/25/2003 8:06:52 AM
meierm01
Status: offline
Got mine on Thursday.
I've assembled many ARFs from World Models, Great Planes, and Hangar 9, and this is, perhaps, the finest ARF I've ever worked with.
Not only is the construction top notch, but the scale details are way beyond a typical ARF - nice instrument panel, corrugated control surfaces, scale looking seats, concealed control.
I'm about 3/4 finished with the kit and it's been mostly been trouble free. There were a couple of differences with the instruction manual, however. Nothing major, but typical of ARF building.
I'll be powering it with an OS 1.60 FX. I'll post more info at completion.
regards,
mark meier
       Post #: 9
Hanger 9 new Skylane - 5/25/2003 5:19:00 PM
SteveD-RCU
Status: offline
How about some pics Mark?or anybody pics please..SteveD
       Post #: 10
Hanger 9 new Skylane - 5/25/2003 11:23:23 PM
sj3cub
Status: offline
I agree with the above post. This arf is absolutley the best
that I have assembled to date. I cannot believe the quality of
this FINE example of the 182. I have the top-flite 182 also, and this bird is giving it a serious run for the money. Parts fit is
dead on and the ultracoat is top notch. I'm about half way done
and have encountered NO problems what so ever. I just hope
that tru-turn has the 3.25 ultimate spinner ready. If you are thinking about this kit then don't, IT IS WELL WORTH THE MONEY. I'm thinking about my Saito 120s for power. Should be enough power to fly it scale like. By the way, the kit was lazer
cut.
Scott Morgan
       Post #: 11
In progress - 5/26/2003 4:29:59 AM
dmyers0403
Status: offline
The first of the two we purchased in underway. Both will be powered by Zenoa G38 with on board starters. Plane wont need the power and it will add a couple more lbs. Originally planed on a Saito 180 but can't resist the on board starter effect. I believe the plane will handle the extra weight just fine (Lot of wing area). Will have to modify (shorten) engine mount unit.
So far everything fits perfect. The flaps are supper neat.
The 120 may be underpowered, this is a good size plane a will produce more drag and weight than the 120 can probably handle, maybe a 150.
       Post #: 12
Hanger 9 new Skylane - 5/26/2003 8:56:01 AM
sj3cub
Status: offline
I wondered about the 120 at first also, but I think it will be fine.
I have a OS pumped 120 surpass in my 15 lb Midwest T6 and it
hauls tail. Plenty of power. So I'm thinking the 182 will come in at
around 17 lbs and with more wing area its should fly scale with
a 16-6 or 16-8.
Scott
       Post #: 13
Hanger 9 new Skylane - 5/26/2003 4:00:13 PM
SteveD-RCU
Status: offline
I think a OS 120 would be fine also for scale flight....SteveD
       Post #: 14
Hanger 9 new Skylane - 5/26/2003 6:16:19 PM
sj3cub
Status: offline
Thanks for your comments Steve. I don't plan on any Unscale
aerobatics........ Stalls, spins, and touch and gos will be it.
Scott
       Post #: 15
Hanger 9 new Skylane - 5/28/2003 10:58:42 PM
flapbreaker
Status: offline
Pictures, pictures, pictures please. I don't care if it's still in the box.
       Post #: 16
Will Post Pictures - 5/28/2003 11:31:05 PM
