ehroof
Score: 105 Joined: 2/28/2006 Last Login: 5/16/2013 From: howard beach, NY, USA Status: offline
quote:
ORIGINAL: UdLose74 I was wondering if the redcat brushless motor was equivelant to the novak 13.5 brushless, that is the brushless system several people are running in the class I'm racing in, but I would like to go with this redcat brushless if possible. i am pretty sure the redcat system is less that 13.5 turns so the redcat system is more powerful but i am sure its not that big of a difference. here are the specs on the redcat system: B4732 Car Speed controller Spec Instructions Features / Specifications: 1. The speed controller is specially designed to offer high power and high efficiency combined with low weight and compact dimensions. 2. Automatic cut–off , auto neutral setting and auto detection of all types and number of cells. 3. Perfect design for direct drive applications. The motor will respond to throttle input & accelerate instantly. There is immediately cut-off motor power when the voltage drops. Move the throttle to the neutral position & then push throttle forwards, the car will run again. Repeat above actions until the voltage drops under its battery’s specific low cut-off volt, the motor will then be completely shut down. 4. Over temperature protection – Status LED1 lights in solid red and Motor will be intermittently turned off when the temperature reaches around 95°c. Optional vent fan is available for selection to enhance the ESC ventilation. 5. Fail safe mode – While detecting out any abnormal signal or signal fail between transmitter & receiver for about 2 seconds, the controller will cut off the motor power automatically. Once the Signal gets back to normal, the system will auto-turn on again. 6. Specifications 6.1 Input voltage : 7.2V ~ 12V DC Ni-Cd / Ni-Mh battery 6.2 Output : Max. 540w/60sec, 225A (at 25°c ) 150A (at 100°c ) under good ventilation Support: A < 5000KV 540S(36X50) motor ( 1/10 car) B < 4000KV 540S(36X50) motor (1/10 cross-country car ) C < 3500KV 540L(36X60) motor (1/10 big-wheel car) 6.3 BEC : 5V 1A 6.4 Mosfet (inner resistance): 0.0166mΩ 6.4 Weight : 90g (fan excluded ) 6.5 Dimension : 45mmx50mmx27 mm 6.6 Exhaust fan: 5v DC, on/off being controlled by system power Operating Instructions: 1. Install the ESC according to the diagram shown below, Switch on the transmitter, Switch on the ESC power 2. Lift the car with the 4 wheels un-touching. Adjust & make sure the throttle forward direction coincides with the ESC forward direction. 3. Right after turn on the power of the ESC, it will denote a series sound indicating the ESC is starting work. It will then auto-setting the throttle Neutral denoted by LED2 in which fast inter-flashing with yellow & red light. While succeed in setting neutral, It will then denoted by another confirmation sound & the LED2 will slowly inter-flash with yellow & red light. If it is failed setting neutral, there will be no any confirmation sound. Please re-do & re-check the system again starting from step1 of this instruction. This ESC is applicable to the transmitter with the setting of 1/2 throttle & 1/2 brake/reverse. 4. Slowly push the throttle trigger forwards, the LED2 will be slowly flashing in red light. The flashing speed should be proportional to the extent of the throttle acceleration. At the full speed, the LED2 will be in solid red light. If the throttle forward direction does not coincide with the ESC forward direction, the light color will be in yellow not red. Change the throttle reversing switch of the transmitter will correct the non-coincidence problem. 5. Motor rotating direction - Slowly apply throttle to check if the motor is rotating in the correct direction you desired. To reverse the direction of the motor, switch any two of the motor wire connections. Note : Do not reverse the battery wire connections! Reversing the battery polarity will permanently damage the ESC. 6. 1stly, trial running starting with a small gear motor for 2~3 minutes, measure the temperatures of both Esc & motor. If both temperatures are close with each other, they are at good match. The gear ratio can then be properly adjusted to optimum according to the features of the courses. However, It’s very important to always keep both temperatures under 100 °c, while adjusting the gear ratio. Otherwise the demagnetization of the motor will happen, the motor efficiency will drop dramatically & the temperature will also raise up very quickly. Most battery power is now wasted on heat nothing on motor efficiency. 7. It’s ok to replace a higher gear ratio or a higher KV motor while the temperature of the ESC is under 80 °c. But it should be done according to para 6 described, from small to bigger. Unless the kv value of the original motor is very low enough, It should replace a motor with lower kv value when the input battery voltage is changed to a higher level. The ESC will be burnt if the motor doesn’t be properly changed while input voltage is changed. See example below on the current changed inside motor while input voltage is changed; Input 7.2V, inner resitance 0.18Ω --- 40A (V/R=I 7.2/0.18=40) Input11.1V inner resistance 0.18Ω --- 61.6A (V/R=I 11.1/0.18=61.6) 8. Driving forward Pull throttle trigger forward, the car will be in hard start mode, with very fast initial start, none delay acceleration, using the minimum time to reach the full speed from still. Perfectly respond to the signal of the instantly acceleration. The braking will be actuated by reversing throttle direction while driving forwards. Interval or spot braking can always be controlled perfectly while driving forwards except when the driving speed drops to certain low level or slip driving happens, which will then reverse to drive backwards after reversing the throttle direction. 9. Driving backwards By reversing the throttle direction when car is in still or very low speed forward driving, the car will be driving backwards. The braking will be actuated by reversing throttle direction while driving backwards. By reversing throttle direction during driving backwards, it will get only a brief braking action & then reverse to drive forwards instantly. The speed of driving backwards will be responded proportionally to the throttle input. 10. Warning - Once the battery pack is connected, handle the model with extreme care, make sure you are clear of all rotating parts. - Connect the battery pack just before drive and disconnect it immediately after termination. - Always make sure you are connecting the ESC to a proper power source that has the correct voltage & polarity. Incorrect voltages or reversed polarity will damage the ESC.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
