Crash: battery at fault?
Tower Hobbies
Logged in as Guest
  Printable Version
*** DV8R PCM Models *** - RTF
Seller:  peter b-RCU
Details:   $8,000.00   |  9/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> Crash: battery at fault?
Page: [1]
Login
Crash: battery at fault? - 2/29/2008 8:57:18 AM
LeeHop
Status: offline
A friend crashed today - total loss of control after about 15 min of perfect flight.
4-cell nicad receiver battery measured 4.9V on meter which includes a load about 10 min after.
Individual cells all measured 1.30 V about 30 min after that. (Battery connector straps removed.)
Do the voltages tell us anything?
This was the only plane in the air at the time and we are at a loss to explain the crash...
Tnx - LeeH
       Post #: 1
RE: Crash: battery at fault? - 2/29/2008 9:57:42 AM
Mr67Stang
Status: offline
Check for power through the ON/OFF switch as well. Unfortunately after a crash you will not know if the crash damaged the switch or not though. 4.9V is fair under a load. and you state that they rose to 1.3V per cell after 30 min (5.2v total). This looks like a strong battery pack. I would charge a pack at 4.9V under a load before flying. After 15 min of flight your freinds battery may have dipped lower than 4.9V as well. How far out was the plane when the loss of control occured?
_____________________________
He who dies with the most toys wins!
(in reply to LeeHop)
       Post #: 2
RE: Crash: battery at fault? - 2/29/2008 11:43:37 AM
Flyboy Dave
Status: online
....true. The voltage was satisfactory, although getting low. More than likely the system
lost power due to a weak connection in the switch. Years ago I had problems with some
new Futaba switches....they were"soft" when you switched them on and off, they were not
crisp and precise. The vibration of the engine makes the switch eventually lose contact.
FBD.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Mr67Stang)
       Post #: 3
RE: Crash: battery at fault? - 2/29/2008 1:07:10 PM
Insanemoondoggie
Status: offline
If he was using Spektrum , at 4.9 volts , he could of had a brown-out.
(in reply to Flyboy Dave)
       Post #: 4
RE: Crash: battery at fault? - 2/29/2008 4:05:54 PM
LeeHop
Status: offline
Ahh so...
The plane was less than 100 yards away when it went down. He was not using Spectrum/2.4GHz.
The switch was found to be off after the crash but we all assumed it was a result of the crash because it couldn't have flown without switch on. You have given us a likely reason, I think: the switch may not have been all the way on to start out with and vibrated off. The switch was autopsied and looked fine inside (no arcing, etc) but we never thought or knew of this problem. It was a Futaba switch by the way.
Thanks - this is a great newsgroup!
-Lee
< Message edited by LeeHop -- 2/29/2008 4:08:42 PM >
(in reply to Insanemoondoggie)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
