RE: DX6, DX6i, DX7 thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: DX6, DX6i, DX7 thread
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: DX6, DX6i, DX7 thread - 5/14/2008 6:42:19 AM
Zimatosa
Status: offline
Not that we do not want to help you here but you should try and post this question in the electric planes Forum...? I just got my radio working for Helicopters and have never tried to set-up a plane for DX6i...Yet!
Good luck,
Z
_____________________________
Without deviation from the norm, progress is not possible.
(in reply to mrjerry42)
       Post #: 76
RE: DX6, DX6i, DX7 thread - 5/16/2008 2:09:52 AM
disney1
Status: offline
Hi All:
Just got a Belt CP and DX6i, have them all set up thanks to the great info on this thread.
Have a question. Flew the heli for the first time today. The responses on the sticks is very touchy. What settings should I use in the Dual rate and Exponential to give me a softer center stick and a responsive full throw.
Have A Great Day
R N Sr.
< Message edited by disney1 -- 5/16/2008 3:18:33 AM >
R/C Helicopters are dangerous to your wealth.
The only stupid question is the one you forgot to ask.
(in reply to Zimatosa)
       Post #: 77
RE: DX6, DX6i, DX7 thread - 5/16/2008 4:54:15 AM
brac1960
Status: offline
negative values give your sticks more sensativity around center, positive values make the sticks less sensative around center. What so you have it set at now??
(in reply to disney1)
       Post #: 78
RE: DX6, DX6i, DX7 thread - 5/16/2008 6:04:31 AM
Zimatosa
Status: offline
quote:
ORIGINAL: disney1
Hi All:
Have A Great Day
R N Sr.
I set my expo for +10 and now I use +15 for aileron and elevator (leave the first row of numbers alone and change the second set to plus numbers for more sensitivity). I do not use any expo for rudder, I like the response to be faster with this control....I have not done anything with dual rate thus far. I do not want to get myself ahead of my little brain...
       Post #: 79
RE: DX6, DX6i, DX7 thread - 5/16/2008 6:22:54 PM
disney1
Status: offline
Thanks brac1960 and Zimatosa:
The info was a big help.
Can't fly now as the wind is very strong. Hopefully I will fly later this evening.
I will play with the Dual Rate after I get the EXPO settings happy. I will post the results so we all can leard.
Have A Great Day
R N Sr.
       Post #: 80
RE: DX6, DX6i, DX7 thread - 5/25/2008 10:57:49 PM
nitrofevr
Status: offline
i am trying to set up a trainer box with my dx6i and i dont know where to go to activate it. the trainer box i am using is a jr max 4 can some one help...
       Post #: 81
RE: DX6, DX6i, DX7 thread - 5/26/2008 12:51:11 AM
eaglewwit
Status: offline
I ordered a DX7, and I believe it comes with digital servos. I also have a Telebee HH gyro coming. Are they compatible? Should I use the stock ESKY gyros?
(in reply to nitrofevr)
       Post #: 82
RE: DX6, DX6i, DX7 thread - 5/26/2008 7:01:49 AM
newflyer6
Status: offline
Wow a lot of good info in here most of the dumb questions I was going to ask have already been answered, yes that means they have already been asked too. I am new to helis so every question I ask seems dumb. I just recently purchased a dx6i for my B-CP and can't wait to get it. I have had one thing after another trying to get everything to work right. The latest sems to be when I get to half stick everything shuts down and my heli crashes to the ground. and I keep loosing my rudder control, the tail rotor will only spin in one direction. I convinced my wife that I needed a trans and reciever and thought what the hell don't want to buy another so went with Spektrum DX6I and hope that this solves the problem she is getting frustrated seeing $500 sitting on my desk.
(in reply to nerdc0re79)
       Post #: 83
RE: DX6, DX6i, DX7 thread - 5/27/2008 9:48:17 PM
noginblue
Status: offline
hi is it possible to change the control stick inputs or outputs, eg i want the rudder stick to work as the aileron stick and visa versa, i do this on my other controllers by moving wires around, can this be done on the dx6i with out soldering stuff like i usually do cheers
(in reply to DirtyBrad)
       Post #: 84
RE: DX6, DX6i, DX7 thread - 5/28/2008 12:48:54 AM
disney1
Status: offline
Evening noginblue:
To the best of my knowledge you can not change the stick asignments via the software. I also would be very reluctant to rewire the sticks.
Have A Great Day
R N Sr.
(in reply to noginblue)
       Post #: 85
RE: DX6, DX6i, DX7 thread - 5/28/2008 6:29:19 AM
noginblue
Status: offline
mmm great will have to learn how to fly all over again how wonderful
       Post #: 86
RE: DX6, DX6i, DX7 thread - 5/28/2008 10:43:55 PM
noginblue
Status: offline
got my dx6i, have one problem, the front servo is acting wierd when i go left or right with the aileron stick the elev ervo goes the same eg left and it goes up and right and it goes down, only moves a small amount with elev stick moved and the aileron servos also move left and right a bit when i move the elev stick up and down, other then that the rudder works great
       Post #: 87
RE: DX6, DX6i, DX7 thread - 5/28/2008 11:31:06 PM
noginblue
Status: offline
on second thoughts could anyone please take a photo of the inside cause i changed two wires round and now cant remember where they go, any help very much apriciated from you very nice fellows and maybe gals, its left stick throttle as well
       Post #: 88
RE: DX6, DX6i, DX7 thread - 5/29/2008 12:50:01 AM
Zimatosa
Status: offline
Photo of the inside of what, the Rx wiring or inside a servo? If you need to know where the wires go hook up the Pitch servo(rear right side looking from back of heli) in 6, Gyro yellow single wire in 5(if applicable), Rudder into gyro and gyro into 4, ESC in 3, Elevator(front servo) into 2, Aileron(right rear on left) into 1....
Hope this helps?
Z
       Post #: 89
RE: DX6, DX6i, DX7 thread - 5/29/2008 1:05:31 PM
disney1
Status: offline
