Extreme Flight Extra 58"
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
"NU B2" ,ARF OR KIT
Seller:  jdep
Details:   $135.00   |  7/2/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> Extreme Flight Extra 58"
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Extreme Flight Extra 58" - 3/1/2008 3:35 AM
sdstick06
Score: 100
Last Login: 6/27/2009
Status: offline
I know there has to be a thread on this plane... can't seem to find it... can someone tell me where I can find it?
Hide Signatures
       Post #: 1
RE: Extreme Flight Extra 58" - 3/1/2008 6:48 AM
Michaelh
Score: 100
Last Login: 7/4/2009
Status: offline
We need to make one? Ill have mine up next weekend, the servo's finally shipped today.
_____________________________
More info on Saito's http://saito-engines.info/
Club Saito #542
Hide Signatures
(in reply to sdstick06)
       Post #: 2
RE: Extreme Flight Extra 58" - 3/1/2008 2:50 PM
sdstick06
Score: 100
Status: offline
Hi Michaelh.... thanks for your reply!
What are your thoughts on the Extra so far?
Hide Signatures
(in reply to Michaelh)
       Post #: 3
RE: Extreme Flight Extra 58" - 3/1/2008 7:26 PM
Michaelh
Score: 100
Status: offline
Its nice, I really like it. The engine mounts could have had a better fit ,but work. Incidences are good, had to tweek a wing a little,like maybe 3/4 of a degree twisted.I dont think many people would even bother with that though.
So far the build has been straight foward. Have not had any problems or issues with it.
The 82a is a nice running little engine also. Going to try a 15x6 with 30% but the 15% on a 14x6 does good.
Club Saito #542
Hide Signatures
       Post #: 4
RE: Extreme Flight Extra 58" - 3/2/2008 12:01 AM
sdstick06
Score: 100
Status: offline
Thanks for the report Michaelh!
Hide Signatures
       Post #: 5
RE: Extreme Flight Extra 58" - 3/2/2008 5:53 PM
Michaelh
Score: 100
Status: offline
Also know that CG may be an issue on these glow conversions. Running the dual elevators may be necessary.
Ill know more for sure later this week.
Anybody else? Reports have said that the plane has dwindled the supply of 5245's so there has got to be more people with this plane.
Club Saito #542
Hide Signatures
       Post #: 6
RE: Extreme Flight Extra 58" - 3/4/2008 1:47 AM
badfish
Score: 100
Last Login: 7/3/2009
Status: offline
I've had mine for a while now.
saito .72
4 5245's
1 225 mg (throttle)
I used the elevator joiner so I could use the second elevator cut-out for a push-pull rudder.
kind of a waste putting 2 $50 servos on the elevator. 5245 on the rudder is plenty also. KE loops no problem.
also frees up the rudder servo pull-pull area for room to mount the battery and rx.
be careful of the canopy/ hatch paint. it chips easily. I took some hinge tape and ran it along the edge of the hatch that goes beneath the cowl.
don't over tighten the spinner screws. It will split the plastic.
when mounting the wheel pants. a bit of 2 sided sand paper in between the landing gear and wheel pant will hold it on a little better. I fly off rough grass and had 1 fly off till I used some sand paper and really tightened them down well.
balanced fine no added weight. just moved my rx battery.
I usually use a apc 13 x 6 propeller on my 72 but came across master airscrew 13x6 S2 series glass filled nylon propeller on tower. I have a new favorate prop for this engine. spins just over 11 grand on the ground and really jumps out of a hover.
steve.
Hide Signatures
       Post #: 7
RE: Extreme Flight Extra 58" - 3/4/2008 2:05 AM
sdstick06
Score: 100
Status: offline
Thanks for the report badfish... it is really appreciated
Can you tell us a bit about the flight characteristics?
Also was the conversion to glow any problem?
SDS
Hide Signatures
(in reply to badfish)
       Post #: 8
RE: Extreme Flight Extra 58" - 3/4/2008 6:25 PM
badfish
Score: 100
Status: offline
plane flys great. almost no coupling in KE. cg will influence this tho. first time I attempted a KE loop I was shocked it didn't flop out of it at the top of the loop. sat right in it like a profile. flat spins great. getting a little rock in upright harriers but I need to add some weight on the left side of my plane. I'm flying with some right ail. trim. landings are a breeze. it will go pretty slow before it looses lift. covering is awesome. I left my pilot and floor out so I could see my fuel tank. which I mounted only half-way back to the wing tube. thats a bit far for most glow engines liking. when I get a chance I'll post a few pics.
the conversion was pretty simple. EF gives you ply already cut to correct dimensions to glue around the firewall. I started gluing them and then realized the firewall has right thrust built in. so certain pieces have exact locations. the ply strengthens the whole front end.
steve
Hide Signatures
       Post #: 9
RE: Extreme Flight Extra 58" - 3/4/2008 6:44 PM
sdstick06
Score: 100
Status: offline
Thanks so much for that info badfish.... it is really appreciated!
Hide Signatures
       Post #: 10
RE: Extreme Flight Extra 58" - 3/4/2008 7:42 PM
sdstick06
Score: 100
Status: offline
Can you use standard size servos? DS821's???
< Message edited by sdstick06 -- 3/4/2008 10:51 PM >
Hide Signatures
       Post #: 11
RE: Extreme Flight Extra 58" - 3/4/2008 9:14 PM
Michaelh
Score: 100
Status: offline
Only on the rudder. Got my 5245's in last night and the CG is working out good so no problems there. Wx dependent Ill have her up this weekend on 30% with a Zinger 15x6 , Im hoping for around 9200 rpm with it but well see. That would be kinda insane
Club Saito #542
Hide Signatures
       Post #: 12
RE: Extreme Flight Extra 58" - 3/4/2008 9:28 PM
sdstick06
Score: 100
Status: offline
Does it look like you might be able to open up the servo holes a little and use standard size servos? Wouldn't take much.... standards are only slightly larger then mini's
mini's 0.7" x 1.3" x 1.2"
Standard 0.75" x 1.49" x 1.52"
Open the width 0.05" and the length 0.19" and ya got it.... pretty sure you would be ok on the depth.... would just be a 0.32 increase in depth
What do you think??
SDS
Hide Signatures
       Post #: 13
RE: Extreme Flight Extra 58" - 3/5/2008 9:32 PM
Michaelh
Score: 100
Status: offline
Nah theres no way on the tail. there is just enough wood to hold the mini's in. the wing has a recessed desighn in it . I may or may not be wrong but wing seems a bit skinny for them also.
Anything is possible I know. But there will be major mods to be done to fit them in.
Ill see what I can show you on a pic ?
Club Saito #542
Hide Signatures
       Post #: 14
RE: Extreme Flight Extra 58" - 3/5/2008 9:50 PM
sdstick06
Score: 100
Status: offline
Thanks Michaelh.... pics not neccesary.... I appreciate it the info!!
SDS
Hide Signatures
       Post #: 15
RE: Extreme Flight Extra 58" - 3/7/2008 4:04 PM
sdstick06
Score: 100
Status: offline
I think I like how badfish did his servos...2 in the rear and no pull pull. That's how my Funtana X 50 is set up and it works great
How well does this the Extra do precision? Is it smooth flying.... does it groove?
I am real close to being able to order mine.... scraping up cash... almost there!!! (very jazzed!)
SDS
Hide Signatures
       Post #: 16
RE: Extreme Flight Extra 58" - 3/7/2008 8:21 PM
badfish
Score: 100
Status: offline
Plane is very smooth in precision flying. I believe I read the fuselage is stretched to help in that area. there is a very good video on FG's site.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by badfish -- 3/7/2008 8:22 PM >
Hide Signatures
       Post #: 17
RE: Extreme Flight Extra 58" - 3/7/2008 9:16 PM
Michaelh
Score: 100
Status: offline
Hey SDS thats what its all about, doing your own thing. There is a video of it with the electric version here http://www.youtube.com/watch?v=iMrl6OYRgx0 other videos also.
You may have seen but if not enjoy!
Weather is poop here so maybe Sunday will bring good flying.
BTW are you on RCG as sdstick?
Mike
Club Saito #542
Hide Signatures
       Post #: 18
RE: Extreme Flight Extra 58" - 3/7/2008 10:54 PM
sdstick06
Score: 100
Status: offline
Thanks guys.... yep sdstick on RCG
What a great video!!!
how much better are the 5245mg's then the 225mg's???? (on a budget here)
SDS
Hide Signatures
       Post #: 19
RE: Extreme Flight Extra 58" - 3/7/2008 11:03 PM
Michaelh
Score: 100
Status: offline
Really were just fooling ourselves with the digitals .The 225's will work great.
Club Saito #542
Hide Signatures
       Post #: 20
RE: Extreme Flight Extra 58" - 3/7/2008 11:11 PM
sdstick06
Score: 100
Status: offline
Oh man... that's great news on the servos Michaelh... thanks
Hide Signatures
       Post #: 21
RE: Extreme Flight Extra 58" - 3/8/2008 12:36 AM
sdstick06
Score: 100
Status: offline
How does it handle in the wind?
Hide Signatures
       Post #: 22
Michaelh
Score: 100
Status: offline
Yep, Check out this video. http://www.****/gallery/showphoto.php?photo=38642
Insert FG's URL where the block is
< Message edited by Michaelh -- 3/8/2008 12:39 AM >
Club Saito #542
Hide Signatures
       Post #: 23
RE: Extreme Flight Extra 58" - 3/8/2008 6:49 PM
sdstick06
Score: 100
Status: offline
How do you think this plane compares to the Fliton Extra 330s freestyle? (might have found an op to buy a Fliton cheap)
Hide Signatures
       Post #: 24
RE: Extreme Flight Extra 58" - 3/8/2008 8:11 PM
Michaelh
Score: 100
Status: offline
I have not flow the 58" yet so I can not compare the two. Although the 330 is a nice flying plane for sure.
Mike
Club Saito #542
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.344RCU1
