jwk72
IL, USA Status: offline
Any idea of where to get this turbo header? If there is a good reason not to use the slimline, I have no problem "leaving it on the shelf". Like I said, this is the first light build I've done and previously weight has not been a real issue. Also, I epoxied my firewall yesterday after installing the nitro conversion kit and went to fit the motor to the mounts and firewall and guess what, it doesn't fit ! Anyone else rubn into this with the Saito 82 and the stock mounts and mounting holes??? Any recommendations? I looked at a number of different mounts from other companies (I work for a LHS so we have alot) but none of the firewall holes line up, do I have to re-drill? -Jay
