RE: Extreme Flight Extra 58"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Extreme Flight Extra 58"
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: Extreme Flight Extra 58" - 4/1/2008 2:06:50 PM
jwk72
Status: offline
Any idea of where to get this turbo header? If there is a good reason not to use the slimline, I have no problem "leaving it on the shelf". Like I said, this is the first light build I've done and previously weight has not been a real issue. Also, I epoxied my firewall yesterday after installing the nitro conversion kit and went to fit the motor to the mounts and firewall and guess what, it doesn't fit ! Anyone else rubn into this with the Saito 82 and the stock mounts and mounting holes??? Any recommendations? I looked at a number of different mounts from other companies (I work for a LHS so we have alot) but none of the firewall holes line up, do I have to re-drill?
-Jay
(in reply to Michaelh)
       Post #: 51
RE: Extreme Flight Extra 58" - 4/1/2008 2:52:21 PM
sdstick06
Status: offline
jwk72....
Bolt the supplied mounts up to the firewall and measure the inside of the beams. The 82 needs 35mm between the beams to mount. See what ya got then you can either get your Dremel and slot the mount holes.... or tap the T nuts out of the firewall... slot the T nut holes and re-install the T nuts (blind nuts)
Hope this helps..
SDS
(in reply to jwk72)
       Post #: 52
RE: Extreme Flight Extra 58" - 4/1/2008 3:43:35 PM
jwk72
Status: offline
Sure does, I just wasn't sure if it was a good idea to mess with either slotting or redrilling the firewall or not. With the stock holes, the flanges on the motor only overlap the motor mounts by about 1-2 mm so I might need to actually re-drill. You think I need to do any re-enforcing after installing the ply form the conversion kit and expoxying the whole thing?
-Jay
(in reply to sdstick06)
       Post #: 53
RE: Extreme Flight Extra 58" - 4/1/2008 3:58:47 PM
sdstick06
Status: offline
Inspect all the glue joints in the motor box and add glue if neccessary. You need to keep the front end light on this one so don't go overboard.
(in reply to jwk72)
       Post #: 54
RE: Extreme Flight Extra 58" - 4/2/2008 1:33:22 AM
Michaelh
Status: online
I think that was my only gripe about the conversion really.
Turbo Header is from RC specialties here on the RCU . http://www.rcuniverse.com/market/item.cfm?itemId=378064
You will love it and its one of the lightest mufflers you can get for it , great sound!
Ill see if I can get a pic uploaded. I got a pic just need to get it on the net.
_____________________________
More info on Saito's http://saito-engines.info/
Club Saito #542
       Post #: 55
RE: Extreme Flight Extra 58" - 4/2/2008 1:45:21 AM
Michaelh
Status: online
Here a couple pics and one of my son with it. Its coming in at 5lbs 6oz dry and will run a tank out in about a half hour in the back yard. Not sitting at idle either .. May go to a smaller tank , well see what flight times are. 15 min is kinda long for me.
See all the room I left for stickers SDS ?
14x6 zinger. Have not tached yet with the Turbo Header but should be up to around 9400rpms now without breaking a sweat
< Message edited by Michaelh -- 4/2/2008 1:48:55 AM >
Club Saito #542
       Post #: 56
RE: Extreme Flight Extra 58" - 4/2/2008 3:12:10 AM
sdstick06
Status: offline
NICE Michael !!!
       Post #: 57
RE: Extreme Flight Extra 58" - 4/6/2008 8:14:34 PM
Michaelh
Status: online
Thanks! Its all ready to go now. Yep another weekend in the rain though,The field is not that far away so I think Ill just put it in my car and go fly after work.
The weekends are always a bust these days.
Club Saito #542
       Post #: 58
RE: Extreme Flight Extra 58" - 4/9/2008 4:17:13 PM
sdstick06
Status: offline
Anybody using a Sullivan tailwheel bracket?
My tailwheel wire broke while shaping it
Michaelh..... have you flown it yet????!!!
SDS
       Post #: 59
RE: Extreme Flight Extra 58" - 4/9/2008 6:38:20 PM
badfish
Status: online
I have the sullivan tail wheel on mine. works well. theres a pic in post 17
       Post #: 60
RE: Extreme Flight Extra 58" - 4/9/2008 6:50:26 PM
sdstick06
Status: offline
Thanks badfish...
How much higher does it sit in the rear then the stock tailwheel setup?
SDS
(in reply to badfish)
       Post #: 61
RE: Extreme Flight Extra 58" - 4/9/2008 7:48:42 PM
badfish
Status: online
just about 2 3/4" from fuselage to bottom of tail wheel. don't know how high stock tail wheel sits.
       Post #: 62
RE: Extreme Flight Extra 58" - 4/10/2008 12:19:12 AM
rc-plane
Status: offline
Just wondering how would a YS 63 do in this plane. Working on a big 50cc plane right now so dont see the plane in my future but I like the looks of the plane.
GO HOGS!!!!! ~ Henderson Rc Flying Club
http://hendersonrcflyingclub.googlepages.com/
       Post #: 63
RE: Extreme Flight Extra 58" - 4/14/2008 9:27:15 PM
Michaelh
Status: online
Ok finally got mine out . Great flying plane, Everything was straight and true! No tracking issues at all . Spent most of the time trying Imac and freestyle.
Switched to a 14x4w at the field and the engine really opened up. Taching a peak of 10,600 rpms vertical is unlimited Id say just right above half throttle.
I set my timer for 10min and brought the plane in 4 times as the timer sounded to check the fuel. So Im just going to say your going to have nice long flights!
Heck the way some fly a tankful may be all you need for the day.
I will have to get ASAP to fly it again with the CG pushed back .
The Y.S is another great choice rc-plane. I believe there are others with that setup in the plane.
Club Saito #542
(in reply to rc-plane)
       Post #: 64
RE: Extreme Flight Extra 58" - 4/15/2008 12:32:55 AM
badfish
Status: online
keep an eye on the hinges. I had 2 break yesterday on the aileron. luckely a friend saw it and pointed it out before I took off.
steve.
       Post #: 65
RE: Extreme Flight Extra 58" - 4/15/2008 12:51:19 AM
sdstick06
Status: offline
My build is going very well....
I used.... and ALWAYS use Radio South Pro hinges... they do not break period. I HIGHLY recomend them.
Love the plane.... can not wait to fly it!!
Thanks for the hinge report badfish.... and very glad you caught it before it caught you.
SDS
       Post #: 66
RE: Extreme Flight Extra 58" - 4/15/2008 6:06:36 PM
flyinGraham
Status: offline
hi guys, sorry missed this thread, I did a build thread when they first came out, mine is electric, you can find it here: http://www.rcuniverse.com/forum/m_6493847/tm.htm
any questions just ask
< Message edited by flyinGraham -- 4/15/2008 6:07:18 PM >
Graham Roscoe
www.freestyle-rc.co.uk / www.extremeflightrc.com
