RE: Extreme Flight Extra 58"
Tower Hobbies
Logged in as Guest
  Printable Version
WILD THING - Kit
Seller:  THOR-RCU
Details:   $55.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> RE: Extreme Flight Extra 58"
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Extreme Flight Extra 58" - 5/12/2008 7:03:19 AM
freeair
Status: offline
yes guys, don,t waiste your dollars on smaller 60 and 70 sized 4 strokes for these 3D type planes, i have both a Funtana and Katana 40 freestyle and the recommended largest size engine is a 70 / 4 stroke which is just not good enough if you want to hover like the heli,s do. go for a good 82 O.S.
(in reply to sdstick06)
       Post #: 101
RE: Extreme Flight Extra 58" - 5/12/2008 9:09:26 PM
Michaelh
Status: offline
I think the Saito .72 would haul this plane around rather nicely. I mean Im hovering below half with the .82 as it is .
_____________________________
More info on Saito's http://saito-engines.info/
Club Saito #542
(in reply to freeair)
       Post #: 102
RE: Extreme Flight Extra 58" - 5/13/2008 12:05:09 AM
sdstick06
Status: offline
Yep... a 72 would be fine.... this thing cruises at 1/8 throttle with the 82
I tested today and got 30 minutes on my 12oz tank.... so.... a 6oz should provide 15 minutes
Also my 82 is new.. I am on my 4th gallon of fuel so fuel consumption will get a little better
I guess I will try the 6oz I have in house next and see how that feels before buying an 8oz
Check me on my thinking here... I am about half crazy (retired pro drummer)
LOVE the plane!!!! Tumbles nice... flat spins both ways quite well.... great high alpha knife edge
SDS
(in reply to Michaelh)
       Post #: 103
RE: Extreme Flight Extra 58" - 5/13/2008 2:22:29 AM
Michaelh
Status: offline
Sounds about right to me. Thats all the flight time I need for one flight anyway.
So being a drummer you should be pretty good on the sticks? I always seem to have the
both hands want to do the same thing delima. Its getting much better though .
Club Saito #542
       Post #: 104
RE: Extreme Flight Extra 58" - 5/13/2008 4:07:14 AM
sdstick06
Status: offline
Ok........ the 6 ounce is all mounted and plumbed.... hope to get out tomorrow and test.... shooting for 15 minute flights.... sure looks tiny in there!! Was able to get the tank all the way up to the firewall so that will help the fuel draw considerably. Might not have to have a pump now.
On the coordination issue..... I do have complete 4 way independence (feet and hands) and am very close to being ambidextrious... from years of training on the drum set... and it does help flying. It is more the instant flow from eye to hand or with music sound to hand with no second thought that makes a good musician or pilot. Train yourself not to think about it... it takes time to think about control inputs before executued. You need to learn to execute the command the instant you think it... you know.... become one with the instrument or machine. Trust the Force Luke!!
Hope that all makes some kind of sense.
This is crazy too..... the 2 things that has helped me the most in flying RC planes is....
Flying helicopters and the flight simulator. I got a copy of G2 for 50 bucks and fly it daily.
Get on the sim and teach yourself to hover a heli.... tail in... nose in... each side too. You will be surprised what it will do for your fixed wing flying skills. It sharpens the hand to eye flow sugnificantly(sp?)
Ok... off my soap box.... hope this helps... I will report the results on the fuel tank change asap.
later,
SDS
       Post #: 105
RE: Extreme Flight Extra 58" - 5/13/2008 4:46:25 AM
Michaelh
Status: offline
I shall try that, I do have a sim I work with all the time then fall off with other projects.
I can get a tourqe roll but thats about it, the thing that gets me with them is the part I thought is hard is the rudder Im having the trouble with the elevator. DOH! I can make corrections belly in no problem like waterfalls etc.
Im decent with most everything else just need to spend more time inverted which I have neglected over the years.
Man I hope my new engine mount getts here this week! I wanna go fly this one again.
Have fun !
Mike
Club Saito #542
       Post #: 106
RE: Extreme Flight Extra 58" - 5/13/2008 5:40:50 AM
sdstick06
Status: offline
Make yourself practice what you DON"T do ...... especially on the sim where it doesn't kill a plane when you crash
Did your motor mount break???!! How??
SDS
       Post #: 107
RE: Extreme Flight Extra 58" - 5/13/2008 6:47:25 PM
insalacosm
Status: offline
Sorry I missed this thread, there wasn't much activity here during my build...
I've been flying mine with the YS .63 and love it! I'm using a 13x6 prop with 30% nitro - yields about 11k RPM. It's a great setup and offers plenty of power while keeping it light for 3D. I'm running a 12 oz tank which gives me about a 15 minute flight time. I could have gotten away with a 10oz tank but I didn't want to empty the tank during a low hover or somthing like that. With the battery pack located behind the rudder servo everything balanced perfectly (using a single elevator servo). A friend at the field was flying his electric version and thought my glow setup had more power; his trottle response time is quicker though. The electric to glow conversion required some work to get things totally fuel proof, but it ended up working out fine. I'm using the Hyde soft mount to keep vibrations down since it is such a light and rigid airframe. The only mods I made were replacing the tailwheel assy, using an Al spinner, painting the cockpit floor black, and using vinyl graphics to jazz it up a bit. I was able to route the muffler inside the cowl by using a stock OS header pipe made for a 70 surpass.
Here's a quick flight report: flat spins and tumbles are great; I get a little wing rock during elevators and harriers so I'm going to try a spoileron mix; stall turns are easy and tight; it weathervanes more than expected but this may be because it is a 3D setup (not very nose heavy); it knife edges without any roll or pitch coupling; the ailerons are so sensitive that I keep turning the rates down; slow flight is excellent and it does not want to snap out; it flies pattern type maneuvers well but the huge control surfaces make it a bit touchy. Overall - it flies great, is tons of fun to fly, and is beautiful.
Here are some pictures of my setup.
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 108
RE: Extreme Flight Extra 58" - 5/13/2008 7:17:25 PM
sdstick06
Status: offline
Nice Steve!!
Thanks for sharing
SDS
(in reply to insalacosm)
       Post #: 109
RE: Extreme Flight Extra 58" - 5/13/2008 9:13:38 PM
Michaelh
Status: offline
Welcome Insalacom! Good to see you over here. This is flyinghigh off RCG .
SDS
Yeah when I had the dead stick the landing gear folded back and the engine mount broke. Id rather the mount break then the box or the firewall though.
I can get another in the glow conversion kit . Wish they sold it seperate . All that should be here this week maybe. Landing gear is halfway repaired ,I just have to
dremel out one of the ends of the rod from the firewall and reaplace with new. They cam out pretty easy so Im sure they are not glued in too good.
I had the engine too lean and just should have stayed on the ground my fault and lesson learned!
Thanks for all the advice also !
Mike
Club Saito #542
       Post #: 110
RE: Extreme Flight Extra 58" - 5/13/2008 9:26:04 PM
sdstick06
Status: offline
Sorry bout your deadstick mishap.... don't fret... she will be better then new when your done with the repair... and she will fly better too!! Watch and see
Your welcome for the advice.... no prob... I am all about helping my fellow pilots.. a lot of people were kind enough to help me along the way.
I was going to go test today but I am not feeling up to it.... maybe in the next couple days between rain showers
SDS
       Post #: 111
RE: Extreme Flight Extra 58" - 5/13/2008 10:07:41 PM
sdstick06
Status: offline
Forgot to mention...
This thing does GREAT snaps!!! On low rates!!!
SDS.... back to Realflight
       Post #: 112
RE: Extreme Flight Extra 58" - 5/14/2008 3:06:25 PM
insalacosm
Status: offline
Hey Mike!
I hear the kits are now coming with one piece CF gear, whereas each leg is separate in mine. I imagine this may prevent some of the LG plate tear outs since the forces will be better distributed across the LG plate. It is disappointing though that the plywood used for the original LG plate is not very solid and delaminates so easily. My rebuilt LG area is holding up well and it helps that I'm running some larger wheels and no wheel pants.
Steve
       Post #: 113
RE: Extreme Flight Extra 58" - 5/15/2008 3:15:57 AM
