osuwins
OH, USA Status: offline
ive had no problems it climbs the wall, my problem is with the rear bent frame the driveshaft hits the rocks i think its to exsposed, i have dings and scrapes after just one try, why do they bend them anyway quote:
ORIGINAL: munro300 quote:
ORIGINAL: osuwins heres mine-- integy 55t motor,LRP esc, hytec 645 servo, 1500mah saddle pack batteries, stage 2 suspension from ckrc, i use the radio from my savage, and futaba 4 channel rx, star cut and trimed foam in tires, weights in the front tires, body cut for competition ps it is about time we have an offical tread, good job Hey OSUWINS, I think it looks like you did the exact stage 2 set-up? If so I would move the lower links back out towards the shocks even if its in place of the spacer, otherwise it gives way too much axel steer. I had mine like that but moved em in, just try driveing up a wall and the rear end will probablly take off to the left instead of following the front. I might be wrong but just try it out.
_____________________________
no matter where you go your allways there
