RE: XYZ ENGINES    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: XYZ ENGINES
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: XYZ ENGINES - 1/16/2011 4:31 PM
jssull00
Score: 100
Last Login: 6/18/2013
Status: offline
Thanks Dave, it worked like a champ. This is a nice motor.
I have 56 flights of 11 minutes each when I noticed a lateral
movement in crankshaft. Need to check it out. This motor turns an
16-8 master airscrew at 8200+. It flies a Seagull Yak 90 very
well.
Hide Signatures
(in reply to jssull00)
       Post #: 276
RE: XYZ ENGINES - 1/19/2011 1:43 AM
jssull00
Score: 100
Status: offline
Well, turns out the bearings are fine (NGK). The
problem is the crank shaft. It was turned down too
small when manufactured. The front journal measures
(.47024") instead of (.47244").
Hide Signatures
       Post #: 277
RE: XYZ ENGINES - 5/27/2011 7:14 PM
microdon2
Score: 110
Last Login: 6/17/2013
Status: offline
A question for any gasser's out there. I was re-tuning my XYZ 50cc gasser this morning - finally got it right. Seems the low-speed needle was too closed, so the engine was cutting out at idle. And I opened up the high speed, which increased RPMs. So, good idle and high end, and smooth transition. Flew perfectly in the air, too, without the cowl. But once I put the cowl back on it ran like CRAP (in the air, seemed ok before takeoff). The engine would not advance to more than (it seemed) 1/3 throttle, no matter what I tried. Sounded like the engine was choking. Got it back safely, took the cowl off, and the engine ran perfectly again. Flew it, sans cowl, perfect engine response. So is the cowl cutting the airflow to my carb? Should I install a venturi to a hole in the cowl? (I've heard of this but never done it before.)
Or could this be a case of installing a nipple into the carb pressure plate and running a line to the body of the plane, for more constant pressure? Thanks.
Hide Signatures
(in reply to jstanton)
       Post #: 278
RE: XYZ ENGINES - 5/27/2011 7:20 PM
microdon2
Score: 110
Status: offline
Also, I'm curious what props and RPM's people are getting with the XYZ 50. I'm finding I get more airspeed with my 78" Texas Hurricane using an APC 18x10. Faster than an APC 20x10. I'm not doing 3D, so am more interested in speed. What props and RPM's are other's getting?
Hide Signatures
(in reply to microdon2)
       Post #: 279
RE: XYZ ENGINES - 5/27/2011 11:47 PM
jssull00
Score: 100
Status: offline
Make sure you have enough exit area for air to
evacuate cowl. If the engine over heats it will lose
power or stop. You should have at least twice the
size hole for letting air out as inlet size. The inlet
should direct air over the cylinder and head and
any other holes covered over.
Hide Signatures
       Post #: 280
RE: XYZ ENGINES - 9/5/2012 10:11 PM
SigMan
Score: 110
Last Login: 6/10/2013
Status: offline
anyone have the XYZ 20cc yet ?
_____________________________
Club Saito Member #1
AMA# 542304
Hide Signatures
       Post #: 281
RE: XYZ ENGINES - 9/6/2012 10:47 AM
Mpizpilot
Score: 100
Status: offline
quote:
ORIGINAL: SigMan
I've got two of them, run great. No issues at all. Real Walbro carb, ngk plug. Both are smoother then my dle 20.
Hide Signatures
(in reply to SigMan)
       Post #: 282
RE: XYZ ENGINES - 9/6/2012 11:21 AM
SigMan
Score: 110
Status: offline
thanks ! 179.99 now @ Vally View RC
AMA# 542304
Hide Signatures
(in reply to Mpizpilot)
       Post #: 283
RE: XYZ ENGINES - 9/8/2012 9:42 AM
Octopus RC
Score: 100
Last Login: 4/18/2013
Status: offline
I think XYZ is transiting from CNC to die-casting . I guess they ca not offer this price very long time .
We Offer XYZ / B&D / TGY / TMM Online Support and offer factory price replacement parts .Wherever and whenever you brought your engine from . Please check www.octopusrc.com . Big Save !!!!
Hide Signatures
       Post #: 284
RE: XYZ ENGINES - 9/8/2012 2:25 PM
microdon2
Score: 110
Status: offline
Octopus - If the price of XYZ 20's increases it will be getting very close to DLE 20 territory. Do you think people will still choose an XYZ over a DLE without much of a price incentive? Do you have any videos for the XYZ 20 on Youtube?
btw - aren't YOU sales XYZ?
< Message edited by microdon2 -- 9/8/2012 4:04 PM >
Hide Signatures
(in reply to Octopus RC)
       Post #: 285
RE: XYZ ENGINES - 9/8/2012 2:36 PM
SigMan
Score: 110
Status: offline
just placed my order for the XYZ 20cc based solely on the review in the new issue of FLY RC installed in the Sig Rascal 110. also ordered the Rcexel Optokill Switich for a grand total of 210.70 shipped ! wish me luck with my first gas engine.
AMA# 542304
Hide Signatures
       Post #: 286
RE: XYZ ENGINES - 9/8/2012 2:40 PM
Octopus RC
Score: 100
Status: offline
No sure what will happen yet.
We do hope people will like XYZ new engines .
We haven't take any video yet.
I think there will have some video post by end users soon.
About wholesale .
At present we offer worldwide wholesale except USA.
Hide Signatures
       Post #: 287
RE: XYZ ENGINES - 9/8/2012 3:53 PM
SigMan
Score: 110
Status: offline
you say "I think XYZ is transiting from CNC to die-casting" why do you say this ? isnt CNC better than Die-casting ?
AMA# 542304
Hide Signatures
       Post #: 288
RE: XYZ ENGINES - 9/8/2012 4:09 PM
Octopus RC
Score: 100
Status: offline
A 20cc CNC engine will cost more than 280USD for retail.
Will you buy it ?
Hide Signatures
       Post #: 289
RE: XYZ ENGINES - 9/8/2012 4:17 PM
microdon2
Score: 110
Status: offline
DLE 20's are Die Cast, right?
Octopus - are you saying the current XYZ 20s are CNC?
Hide Signatures
       Post #: 290
RE: XYZ ENGINES - 9/8/2012 4:36 PM
Octopus RC
Score: 100
Status: offline
DLE20 is die-casting , and XYZ 20 is die-casting too.
Hide Signatures
       Post #: 291
RE: XYZ ENGINES - 9/9/2012 11:37 PM
secret_squirrel
Score: 100
Last Login: 6/5/2013
Status: offline
Hi all, hope to get some help here. I have an XYZ 53 twin. Love the engine so far but I haven't had more than 10 flights on it. Flew it two weeks ago and everything was peachy. Mtoday I got to the field and flipped it till I got a headache and it never started. I noticed fuel coming out of the carb so that wasnt the problem. On to spark. I pulled the plugs, grounded them against the jugs and no spark. I pulled off the ignition and noticed one of the black wires, the one that goes to the timing part on the engine, had some of the plastic covering scraped away. I put some electrical,tape over it and plugged everything back up. Now when I turn on the egnition switch, the ignition module hums. What dies this mean? Engine still didn't spark after numerous flips. New to gassers so any assistance would be greatly appreciated.
Also, if the diagnosis is the ignition module, can I just get any ignition module or do I need one compatible with this engine? Not sure I like the xyz ignition module if it craps out after 10 flights.
Thanks in advance,
Dan
Hide Signatures
       Post #: 292
RE: XYZ ENGINES - 9/10/2012 2:21 AM
Octopus RC
Score: 100
Status: offline
Hello Dan
Can you e-mail us the picture of your ignition at sales@octopusrc.com ?
We can check and require free replacement for you if it`s a old version from factory !
I guess the bad sensor cased ignition short out .
Have a good day !
Hide Signatures
(in reply to secret_squirrel)
       Post #: 293
RE: XYZ ENGINES - 9/21/2012 7:39 PM
kwik
Score: 105
Status: offline
quote:
ORIGINAL: secret_squirrel
Thanks in advance,
Dan
I have the XYZ 53 cc. Bought 4 RcExl ignition modules from Octopus RC.
2 to a Saito FG-57 and 2 to the XYZ 53 cc.
The two first worked for, say 10-10 flights. Then the spark becomes too weak.
The engines wont start.
So I bought 2 more in june this year. One of them never gave a spark. The other one can be started,
but only after, say, 10 - 20 seconds on a starter.
I also have RcExl on a G-38. Its beginning to show the same symptoms.
I have another set on a GT-80. It has been working so far, but it dont have that many flights yet.
I fear it will fail too.
Will try C&H Ignition now.
There is a discussion on it here;
http://www.rcuniverse.com/forum/m_11223166/tm.htm
< Message edited by kwik -- 9/21/2012 8:34 PM >
Hide Signatures
       Post #: 294
RE: XYZ ENGINES - 9/21/2012 8:53 PM
BadAzzMaxx
Score: 453
Status: offline
I have sold well over 250 RCexl ignitions sense the first of the year and you have had more failures than all of them put together, You must have the worst luck of anybody I have ever seen or just doing something wrong.
And on another note, They have a two year warranty so why did not Octopus RC replace them.
Milton
Contact Milton@rcextremepower.net
Team RCeXtremePower.com
Hide Signatures
(in reply to kwik)
       Post #: 295
RE: XYZ ENGINES - 9/22/2012 2:35 AM
Octopus RC
Score: 100
Status: offline
Both Rcexl and Octopus RC will offer warranty service . it's no problem.
But i can not understand why the 4pcs Dan brought all have problem ?
Never met this before .
Hide Signatures
(in reply to BadAzzMaxx)
       Post #: 296
RE: XYZ ENGINES - 9/22/2012 2:51 AM
BadAzzMaxx
Score: 453
Status: offline
quote:
ORIGINAL: Octopus RC
Same here. ????
Milton
Hide Signatures
       Post #: 297
RE: XYZ ENGINES - 9/22/2012 2:58 AM
Octopus RC
Score: 100
Status: offline
what does the "same" about ?
Hide Signatures
       Post #: 298
RE: XYZ ENGINES - 9/22/2012 2:59 AM
acerc
Score: 221
Last Login: 6/19/2013
Status: offline
There is one common denominator in those types of circumstances.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 299
RE: XYZ ENGINES - 9/22/2012 3:06 AM
BadAzzMaxx
Score: 453
Status: offline
what does the ''same'' about ?
I agree with you.
Milton
Hide Signatures
       Post #: 300
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: XYZ ENGINES
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
