RE: XYZ ENGINES
Tower Hobbies
Logged in as Guest
  Printable Version
RCS 215 cc Radial - RTR
Seller:  Barnstormer
Details:   $3,000.00   |  9/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: XYZ ENGINES
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: XYZ ENGINES - 6/17/2008 2:16:57 AM
jstanton
Status: offline
Ron
I would like a wrap around muffler also for my P-40 if you have one.
_____________________________
Jim Stanton
Millington, TN 38053
(in reply to john d in texas)
       Post #: 101
RE: XYZ ENGINES - 6/19/2008 8:44:40 PM
DairingDave
Status: offline
Hi all I just installed a xyz 26cc gas engine in a hanger9 Twist 150,the engine runs grate.startes easy a little cold nature though.it swings a top flite 16x8 power point prop to 7100rpm and has plenty of power to fly the twist quite nicely.it wont do a lot of 3D stuff though but plenty of power for most other flying.ron was nice and is easy to talk with,,dave in arkansas
(in reply to jstanton)
       Post #: 102
RE: XYZ ENGINES - 6/20/2008 4:48:13 AM
jstanton
Status: offline
I have finished my Skyshark P-40 with the XYZ-50 engine. I hope to do the maiden next Saturday June 28th. This weekend is taken up with family oblications. I hope to get some video I plan on posting here for you all to see. MY XYZ-50 is spinning a Bambula 20x10 prop at 6900RPM. Here is a pic. I have since installed the decals.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Jim Stanton
(in reply to DairingDave)
       Post #: 103
RE: XYZ ENGINES - 6/23/2008 11:17:00 AM
jstanton
Status: offline
Well I finally got the maiden flight in this weekend. The XYZ-50 ran perfectly. Started easy and had more than enough power for my 21lbs Skyshark P-40. I have some video being processed that I hope to have ready by tomorrow. I will have a link to it setup asap. This is a great running engine for War Birds.
Jim Stanton
       Post #: 104
RE: XYZ ENGINES - 6/25/2008 5:59:14 PM
SWORDSN
Status: offline
Ron, or anyone that has an opinion , I am building a KMP B-25 arf . How do you think two 26cc engines would perform? The plane should weigh 17-18 lb.
       Post #: 105
RE: XYZ ENGINES - 6/25/2008 6:13:04 PM
jstanton
Status: offline
Here is the video of my maiden flight of the Skyshark P-40N with the XYZ-50. It weigh's in at 21lbs spinning a Bambula 20x10 prop.
http://www.youtube.com/watch?v=mPFUSwCW5_k
Jim Stanton
(in reply to SWORDSN)
       Post #: 106
RE: XYZ ENGINES - 6/27/2008 4:00:04 PM
XYZUSA
Status: offline
quote:
ORIGINAL: SWORDSN
I beleive they might be a little to big.
Compare the 26cc to a 120-140 Nitro Two Stroke.
Ron
Southeast R/C Engines
www.southeastrcengines.com
"The low cost leader in gas engines"
       Post #: 107
RE: XYZ ENGINES - 6/30/2008 4:28:31 AM
desmond43
Status: offline
Jim do you think this XYZ 50 will work in a World Models GS P-51? I have run a moki 2.10 in it with great results and I want to know if this would fit and the power comparison. Let me know your thoughts please. Thanks, Phil
       Post #: 108
RE: XYZ ENGINES - 6/30/2008 11:03:26 AM
jstanton
Status: offline
Phil,
I do believe the XYZ-50 would fly the WM GS P-51 quite well. I also think it would weigh a little more than with the Moki 2.10 and have a little less power. The good thing is it would pay for itself in the long run. My P-40 weigh's 21 lbs with 1190 sq in wing aera. Your P-51 woulb be around 18lbs with 1155 sq in wing aera. The XYZ weigh's 3lbs 10oz. What does the Moki 2.10 weigh?
Jim Stanton
(in reply to desmond43)
       Post #: 109
RE: XYZ ENGINES - 6/30/2008 5:06:21 PM
jstanton
Status: offline
Phil,
I just did a search on the Moki 2.10 you are using and it weigh's 45oz without the muffer. If the muffler even weigh's another 3oz that makes the Moki 2.10 weigh in at an even 3lbs. I bit it is a bit more than that. The XYZ-50 weigh's only 3lbs 10oz compete with muffler and EI. It spin's a Bambula 20x10 prop at 6950 with only 2 gallons of fuel thru it. It well be even better once competely broke-in. I bit your WM GS P-51 world weigh only another 6oz or so over your current weight. Just think of the savings in fuel a lone and you would see the XYZ-50 would more than pay for itself.
Jim Stanton
       Post #: 110
RE: XYZ ENGINES - 7/18/2008 3:31:51 AM
nowinkk
Status: offline
My xyz26cc vibrated too much on the test bench, so I have no guts to put it on an airframe to fly. It is now lying in the store collecting dust. Any idea what should I do about it?
Life ends when u stop dreaming; Hope lost when u stop believing n Love fails when u stop caring. So dream, believe n care..
       Post #: 111
RE: XYZ ENGINES - 7/18/2008 1:36:28 PM
jstanton
Status: offline
If it is still under warranty I would send it back to who ever you purchased it from for a replacement. The XYZ engines fron Southeastengines here in the states would be gladly replace by Ron.
Jim Stanton
(in reply to nowinkk)
       Post #: 112
RE: XYZ ENGINES - 7/18/2008 2:29:58 PM
XYZUSA
Status: offline
quote:
ORIGINAL: john d in texas
Ron, Did I read somewhere that you are making a different type of muffler for the 50 also ??? Would a wrap behind type work on it, or would it not save any of the width problems ?? Thanks again, John D....
Yes, Pitts Style Mufflers are coming for 26 & 50.
Due in week of 7/28/08.
Proto-type testing went very well, got 300 more rpm
on the 26 after install.
Ron
       Post #: 113
RE: XYZ ENGINES - 7/18/2008 3:02:53 PM
XYZUSA
Status: offline
quote:
ORIGINAL: nowinkk
We suggest you send it back to HC and demand a replacement.
However, we were told by one of our customers that it took close
to a year for them to replace it, but they finally did.
Before any engine goes out of our shop, we go through a 14 item
checklist and one of the items on the list is to check for shaft
out of round.
Back in March, we had three from a batch of engines that had this
problem and were fixed before they left the shop. Since that
batch, XYZ changed the design to include a collar that seated the
hub so it could not shift during installation.
SERCE
Ron
       Post #: 114
RE: XYZ ENGINES - 7/19/2008 8:36:58 AM
nowinkk
Status: offline
I think Id beter send it back for a replacement.
However, I wonder if I should send it to HC or return to the factory directly.
I believe it would take a much longer time to send to HC.
This engine is already 6 months' old since its arrival and with all those bent crankshaft and faulty ignition problem, I have not been able to mount it on an airframe to fly it. Would the factory accept it back and give me a replacement?
(in reply to XYZUSA)
