RE: XYZ ENGINES
Tower Hobbies
Logged in as Guest
Users viewing this topic: TDogAce, Baldeagle, antiquefer
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: XYZ ENGINES
Page: <<   < prev  2 3 4 5 6 [7] 8 9 10 11   next >   >>
Login
RE: XYZ ENGINES - 9/28/2008 6:07:09 PM
fabmaster911
Status: offline
Mr. Edge, you couldn't hover a plane to save your @$&. LOL
(in reply to MrEdge)
       Post #: 151
RE: XYZ ENGINES - 9/28/2008 9:32:13 PM
MrEdge
Status: offline
I love when my friends talk $#!^ on forums!!!!
_____________________________
Slow and low is the only way to go
(in reply to fabmaster911)
       Post #: 152
RE: XYZ ENGINES - 9/28/2008 9:37:20 PM
fabmaster911
Status: offline
Yeah, it's a small world. He actually can fly guys.
       Post #: 153
RE: XYZ ENGINES - 9/29/2008 8:17:08 PM
Keemos
Status: offline
quote:
ORIGINAL: GregT882762
I just bought an xyz 50 for my 74 yak extreme flight,ran i 2 times last last night,seems to have great power, maybe too much for this little plane,we will see,throttlemanagement will definitely be a must!!!
I had the chance to maiden mine last week… you’ll be happy with this combo. It will hovers at less than half of throttle input… and will pull vertical with out any problem.
Dennis
(in reply to GregT882762)
       Post #: 154
RE: XYZ ENGINES - 9/30/2008 1:30:34 AM
GregT882762
Status: offline
what prop r u running tell me about ur battery setup and placement if possible
(in reply to Keemos)
       Post #: 155
RE: XYZ ENGINES - 9/30/2008 7:55:45 PM
Keemos
Status: offline
Greg…
I’m running a Xoar “the sword” 20x10 prop. I’m getting around 6400… running rich. I didn’t want to play around with the engine’s settings too much since I’m new to gasser. As for the batteries… I’m using NoBS Elite 2000 pack… 4 cell for the ignition and 5 cell on the receiver. Attached are some pics of my setup. (Note: 5 cell pack is under rudder servo.) Hope this helps...
Dennis
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Dennis
       Post #: 156
RE: XYZ ENGINES - 9/30/2008 10:42:14 PM
GregT882762
Status: offline
thanks for the pics im out of town till tomorrow night so i hope to run mine a little more and move my batteries back also,them maiden it with new motor sometime thursday afternoon,im also running the 20 x 10 Xoar
       Post #: 157
RE: XYZ ENGINES - 10/2/2008 1:59:22 AM
DAN REISS
Status: online
Hi Ron, Are you still there? Please send me an Email. Dan.
(in reply to XYZUSA)
       Post #: 158
RE: XYZ ENGINES - 10/3/2008 12:34:58 AM
GregT882762
Status: offline
Can nyone tell me what the factory settings are on the needles,mine runs crap today,has been running fine, i guess i have 2 tanks throught it but now im sure the needles are of out adjustment whatr the factory setting so i can startr there? 50cc
(in reply to DAN REISS)
       Post #: 159
RE: XYZ ENGINES - 10/3/2008 12:47:58 AM
DAN REISS
Status: online
Has anyone heard from Ron lately? I'm having trouble getting a reply from him. Dan.
       Post #: 160
RE: XYZ ENGINES - 10/3/2008 1:17:55 AM
Keemos
Status: offline
Factory needle settings:
Low: 1.5 turns out
High: 1.75 turns out
Dennis
       Post #: 161
RE: XYZ ENGINES - 10/3/2008 1:32:03 AM
GregT882762
Status: offline
thnks,is ur low speed sluggish still or have you gotten past that part?
       Post #: 162
RE: XYZ ENGINES - 10/3/2008 2:10:14 AM
Keemos
Status: offline
low speed idle is still sluggish... getting around 2300 on the tech. i'm pretty sure i'm running very rich. I only have 6 tanks through it so far. I'll be playing with the setting this weekend.
Dennis
       Post #: 163
RE: XYZ ENGINES - 10/3/2008 1:17:25 PM
XYZUSA
Status: offline
quote:
ORIGINAL: DAN REISS
I am still here Dan, left you an email !
Spent the past 3 days dealing with a CPU virus,
had to get a brand new computer.
Using the wife's laptop until I get it setup.
Ron
Southeast R/C Engines
www.southeastrcengines.com
"The low cost leader in gas engines"
       Post #: 164
RE: XYZ ENGINES - 10/3/2008 1:36:41 PM
JRAllen
Status: offline
xyzusa,
I just bought the CMPro Gile 202 140 V2 and I am considering putting the xyz26 on it.What kind of proformance can I expect. I would like some vertical but nothing extreme. I fly mostly pattern.
Jamie
       Post #: 165
RE: XYZ ENGINES - 10/3/2008 3:23:40 PM
MrEdge
Status: offline
JRAllen,
I had my XYZ26cc on the Phoenix models extra 330...That plane weighed about 9 lbs. I was still in the break in period before I sold it but on a 9 lb plane it had no vertical. I fly somewhere around the 5000ft above sea level mark. IT would prolly pull your Giles around but I would say there would be no vertical pull on a straight up line.
I would seriously consider getting the 50cc instead. It has quite a bit more power but not so much that you are going to rip the firewall off. If you read back thru this thread, you will see the talk about the 50cc going on the Extreme Flight Yak. THat plane is roughly about the size of the CMP Giles you have. I would still reinforce the firewall of the CMP giles regardless of what engine you get...
Hope this helps
(in reply to JRAllen)
       Post #: 166
RE: XYZ ENGINES - 10/4/2008 10:26:25 PM
GregT882762
Status: offline
NOthing good to report here, the motor ran good on first start of the day but ever since is popping and sputtuering,have made small adjustments,but nothing wo
