Vista and Aerofly.... help.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Vista and Aerofly.... help. Page: [1]
Login
Vista and Aerofly.... help. - 3/2/2008 1:32:43 AM
trioval00
Status: online
ok, i have been at this too long trying to download but can't so here I am turning to you for some help. I just purchased Areofly professional delux with all the add-ons.
it will not load. I have tried to look for OpenGL downloads but could not find them.
I am running a new computer.
microsoft vista home premium edition x32
Direct X version 10.0
3.00GB
2 quad cpu
hard drive 1 298.09
hard drive 2 300
video card is
Geforce 7350LE
7.15.11.6925
latest upgrade on GeForce
What downloads do I need for this to run?
What am I missing?
thanks for the help........
Mark
< Message edited by trioval00 -- 3/2/2008 1:46:02 AM >
_____________________________
JPO District III rep - CD 272341, Facet 1700RG
www.jpnepa.com Skymaster Jet
       Post #: 1
RE: Vista and Aerofly.... help. - 3/2/2008 2:55:05 AM
trioval00
Status: online
ok, i found the problem, it was on my end, i missed the part where I had to turn off UAC, onceI did it downloaded fine and it works.... now i cant seem to get full scale going.....
Mark
(in reply to trioval00)
       Post #: 2
RE: Vista and Aerofly.... help. - 3/2/2008 2:00:51 PM
rajul
Status: offline
Hi Mark, did you get any error message? Are you using a DVD drive to install?
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
       Post #: 3
RE: Vista and Aerofly.... help. - 3/2/2008 3:39:51 PM
trioval00
Status: online
Rajul. I have installed the software and works great, all I had to do for Vista was turn off UAC. When i loaded True Scale, it did NOT start by itself, a window popped up with 11 files in it, i clicked on a few of the set up files until it loaded and now True Scale works fine.
only problem i have is when i went to load one of the add-ons, Starflight add-on 2, a window came up saying i had to delete other install to in stall this one.
this add-on i was trying to load is version 1.9.7.9. as where the soft where that i origanally loaded is 1.11.7.1
Mark
(in reply to rajul)
       Post #: 4
RE: Vista and Aerofly.... help. - 3/2/2008 4:05:15 PM
rajul
Status: offline
Try installing patch 1.11.7.9 http://www.aerofly.com/www/downloads.html
Mike Marks
RCU Moderator
       Post #: 5
RE: Vista and Aerofly.... help. - 3/2/2008 4:20:32 PM
rajul
Status: offline
Let me check which addon(s) is included in main disk version 1.11.7.1
Mike Marks
RCU Moderator
(in reply to rajul)
       Post #: 6
RE: Vista and Aerofly.... help. - 3/2/2008 4:33:36 PM
rajul
Status: offline
Mark, it looks like AFPD version 1.11.7.1 comes with addon1 and addon2 in the same disk. That explains why you're getting the error when trying to install addon2 after the main disk. In general, the sequence of installation should be main disk, addon(s), then the correct patch.
Mike Marks
RCU Moderator
(in reply to rajul)
       Post #: 7
RE: Vista and Aerofly.... help. - 3/4/2008 4:43:51 AM
trioval00
Status: online
Rajul, Last question, after all is done and working, Do I still need to have the UAC turned off? or can I turn it back on after all downloads are done.....
Mark
       Post #: 8
RE: Vista and Aerofly.... help. - 3/4/2008 6:53:21 AM
rajul
Status: offline
Should be OK
Mike Marks
RCU Moderator
       Post #: 9
RE: Vista and Aerofly.... help. - 3/4/2008 3:41:11 PM
SoCalSal
Status: offline
quote:
ORIGINAL: trioval00
Mark
You can do it both ways. If UAC is "ON" you will have to open AFPD as the "adminastrator" every time everytime you launch it. If you are the only person useing the computer then UAC is not needed.it helps prevent others from loading and deleting anything.
Let''s be open minded.... But not so open that your brain falls out
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
