mclina
MA, USA Status: offline
Yes. The calculator I used for CG puts it at 11.5" back from the nose. I marked the CG and then positioned the battery to hit it. The battery is held on with velcro tape and a velcro strap, so I can easily make about 1" worth of adjustments without changing anything. Bigger adjustments will just require that I move the hole that the velcro strap goes through. I don't expect this thing to survive much of a crash. The stabs are held on with toothpicks and Gorilla Glue, and the 4mm coro wing is not reinforced at all. I figure I have one try to make this thing work. I have plenty of coro and yardsticks, so I hope I learn enough to make the next one better. Tomorrow's forecast is for 50 degrees, sun, and 3mph winds at lunchtime. I am planning on maidening this thing, my new Derelict, and my .25FX Delta. My photographers will be in school, but I'll let you know how they all fly.
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
