jetpack
IN, USA Status: offline
I rinsed the sponge clear with water first then added just a dab of copper cream to it and squeezed the sponge a few times to get the cream through the sponge, and then just lightly buffed the piston and it came out nice and clean without hurting its size. The head button what I did was spread some copper cleaner on the counter next to the sink with my finger in a thin layer and set the sleeve down square on top of it to be sure not to get any down the sleeve, then CAREFULLY placed the head button into the sleeve and very gently turned it against the top of the sleeve upside down so none of it would run down into it. You want to lap the head with the sleeve on top, and the head upside down on the bottom. Let the gravity hold the cream where it should stay - away from the sides of the head where it fits into the sleeve. If you feel anything start hitting on the pilot diameter, stop right away, and rinse everything off and dry it and do it again. After the first light lap, you look and you'll see exactly how well the fit is the first time, and it tells you how much more you have to go. Don't hurry this. Several light tries are better than one, heavy handed mistake. As soon as you feel the cream stop being gritty, and become smooth when you turn it. STOP! Rinse and check. Otherwise if you keep going, the smooth will all of a sudden turn to galling. You don't want that to happen. You should feel the sleeve "float" with the cream in it. As soon as this cushion of cream stops being easy to turn, this is when you stop and look. The harder surface, this time the top of the sleeve, should be checked with a flat stone first to make sure the surface has no dings, and is smooth all the way around. Remember this surface is going to mirror itself into the aluminum, and if it has dingers in it, they will cause deep grooving when you lap into the head. Lapping parts are very tricky at first like I mentioned before, it is easy to cause problems if ultimate care isn't taken, and telling yourself to stop right away and rinse everything and look before things get bad if you sense anything not going good.
< Message edited by jetpack -- 3/7/2008 8:41:00 PM >
