How do YOU polish up your engines?
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> How do YOU polish up your engines?
Page: [1] 2 3 4   next >   >>
Login
How do YOU polish up your engines? - 3/2/2008 10:52:15 PM
fiery
Status: offline
I have just soaked and cleaned up a couple of engines, and the cases have unfortunately developed a tarnished dull look.
I would like to get back the "new" look to the alloy? Mine have darkish fine surface blotches. It's not dirt.
If you have a tip, let me know your procedure ...
< Message edited by fiery -- 3/3/2008 11:58:05 PM >
       Post #: 1
RE: How to YOU polish up your engines? - 3/2/2008 11:18:38 PM
Bone
Status: offline
Yes, I'd like to know the answer too. I have an OS20 FS that needs a gentle but effective polishing treatment. I have tested a german made metal polish that works well on the "easy to get at places" using a rotary tool with the felt wheel. But near impossible to get the wheel into the smaller crevices etc
(in reply to fiery)
       Post #: 2
RE: How to YOU polish up your engines? - 3/2/2008 11:24:41 PM
jetpack
Status: offline
A small, wooden handled stainless steel brush will work good. Look for them at Ace Hardware or such near the welding or soldering stuff.
You HAVE to be careful around sharp outside corners as it will leave tiny scratches, but for the most part it will be stiff enough to hold up to scrubbing in inside corners pretty well. I use a copper cleaning paste along with it from the grocery isle. It is a messy deal but it will bring back the finish pretty well.
The trick is making sure you use copper cream, because there is a good trace of it in cast aluminum, and the dulled brass that is in it is part of the problem. Plus it is all water based and rinses off very well just at the sink.
They also work very well for removing sharply machined, non-deburred corners in aluminum.
You could try just the copper cream and a stiff plastic brush if your unsure of wanting to leave minute scratches that the stainless will make. You could use a brass brush and it will not leave any scratches, but those bend up and mushroom over in zero time with any kind of hard scrubbing.
Sorry there isn't any chemical cleaner that can be used like Tarnish Remover, other than what is called a "de-smutter" used by professional air conditioner cleaners. It is hard to find and is a nasty chemical, and haven't really used it to tell you how well it works or if it will eat threads or ruin bearing fits.
Sorry I don't have very good before and after shots but the Webra on the left was very used and anti-freeze cooked with lots of grey, and the little OPS was bought new but just tarnished from sitting.
The stainless brush really does a good job at getting inside the fins, and does leave a glossy sheen to what is grit blasted. Smoothes out the sharpness of it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by jetpack -- 3/2/2008 11:46:12 PM >
(in reply to Bone)
       Post #: 3
RE: How to YOU polish up your engines? - 3/3/2008 1:17:21 AM
daven
Status: offline
Nice work Jetpack.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to jetpack)
       Post #: 4
RE: How to YOU polish up your engines? - 3/3/2008 1:23:14 AM
w8ye
Status: offline
Just glass bead blast them
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to daven)
       Post #: 5
RE: How to YOU polish up your engines? - 3/3/2008 1:33:54 AM
jetpack
Status: offline
Thanks Daven! I like my motors
Yep, glass beading works really well...but be sure to do a good job of masking or bolt all the cases up then bead blast. The only thing you have to be careful of with glass beading is it leaves itself in the aluminum, and if your not careful on washing and scrubbing afterwards, it can find its way into the motor and eat pistons and bearings. Its a little risky in that respect, otherwise its probably gives the best result. They sell a pulverized walnut shell medium for blasting which would be totally safe, but probably not reach as well as glass.
< Message edited by jetpack -- 3/3/2008 1:40:04 AM >
(in reply to w8ye)
       Post #: 6
RE: How to YOU polish up your engines? - 3/3/2008 2:25:06 AM
Kmot
Status: offline
I prefer brass brushes myself. Softer, less chance of scratching the aluminum, and yet cleans well.
Ahhh......screw it!
       Post #: 7
RE: How to YOU polish up your engines? - 3/3/2008 2:26:09 AM
LeeHop
Status: offline
Thanks for the pix, jetpack - those engines look beautiful.
Re: masking for glass beading - how do you do that?
Tnx - LeeH
       Post #: 8
RE: How to YOU polish up your engines? - 3/3/2008 2:34:50 AM
w8ye
Status: offline
I've used electrician's tape and masking tape with success
Original AMA #31261
(in reply to LeeHop)
       Post #: 9
RE: How to YOU polish up your engines? - 3/3/2008 3:57:38 AM
rainedave
Status: offline
quote:
ORIGINAL: jetpack
Beautiful work jetpack. Thanks for the copper polish tip. I think Enya must use aluminum with a high copper content because of all my engines they are the worst to turn dark gray and blotchy. My Super Tigres seem to be the least effected by tarnishing.
David
       Post #: 10
RE: How to YOU polish up your engines? - 3/3/2008 10:08:47 PM
Bone
Status: offline
quote:
ORIGINAL: Kmot
Tom - do you apply a lubricant (eg: kerosene or ATF) to the brush / engine with your technique or simply brass on the aluminum ?
(in reply to Kmot)
       Post #: 11
RE: How to YOU polish up your engines? - 3/3/2008 10:17:05 PM
Kmot
Status: offline
If there is oil, castor crust, etc yes I use a solvent like Stoddard. If it is a clean case or part, but oxidized or discolored I brush it dry.
Ahhh......screw it!
(in reply to Bone)
       Post #: 12
RE: How to YOU polish up your engines? - 3/3/2008 11:09:25 PM
djr1007
Status: offline
There is a chemical method, but you need to be cautious!
Get an old crock pot, set it on low and fill with antifreeze and just dunk your engine in for a day or two.
CAUTION, this creates fumes that are really nasty on your lungs. It's a good idea to set the whole crock pot down inside of a large garbage can. This contains the fumes (they don't rise). Be sure to unplug the pot and let cool before sticking your head down into the can to retrieve your engine.
This will take off all of that tarnish without any hard work, just take care not to breath the fumes.
(in reply to Kmot)
       Post #: 13
RE: How to YOU polish up your engines? - 3/4/2008 5:35:37 PM
stg61abc
Status: offline
Wow, gorgeous work Jetpack!!!! fantastic results!!
       Post #: 14
RE: How do YOU polish up your engines? - 3/4/2008 9:57:44 PM
blw
Status: offline
I agree, great work Jetpack!
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to stg61abc)
       Post #: 15
RE: How do YOU polish up your engines? - 3/7/2008 12:15:02 AM
