tam popo
Joined: 2/6/2007 From: glasgow, , UNITED KINGDOM Status: offline
Hiya guys - had a second fly of the EZCub, not too good!! I couldn't use my usual flying site cos of Illegal use by kids on Motorbikes, litle sh..s So I had to hand launch this 54in w/span plane from my slope site. Nearly full throttle with just a touch o up elevator had it shooting off and lightly up....no problems there. But when I had to apply some control on the rudder and elevator it was as twitchy as a drug addict doing col turkey...all over the place. I just managed to get it down without too many problems (just a nose over on grass) and went home o check everything. All was Ok, CoG spot on, elevator settngs as per manual (15mm up ele, 12mm down). Now I love the DX6i, its cheap, advanced as they come, full range and oodles of settings to play around with.....but there's a problem!!!!! The manual explains all there is to know about setting up the TX, expo, trim, everything. But not a bloody sentence to explain WHY you need this or that applying. What do I set if the plane is twitchy, what do I set if it wants to stall all the time etc....Nothing, Nada, Zilch. Please, please someone point me to a site or somewhere that explains the info I need. Even input from your goodselves is better than none. To explain the flight....I applied a little up elevator to climb at a normal rate (30*) and the thing went vert. Thats not an exageration, it went Vert big time. I'm used to Strykers doing that but you don't expect it from so-called Slow-Flyer on a 250W o/runner on 2200 2S, 54in w/span and weighing 850+grm. Frightened the sodding life out of me - keep your EDF's , I'd beat you any day flat out...... Got to go to my LHS for n u/carriage for the BWacker....more money!! See you all tonight.....unless you've moved
_____________________________
Born to fly and loose my postings on RCU......
