Kaelan
GA, USA Status: offline
ok... I said buy cheap buy twice.. I say this from experience.. I don't have a trex.. I don't have the best radio.. I don't have the best servos or gyro.. I bought a Black Hawk 450SE from ka-planes.com personally I think it's a great heli..and I highly recommend buying from ka-planes because Mike is a great guy and the service is first rate.. BUT, it does have cheap servos (same tower pro 9g servos in the heli you asked about). They're real cheap.. cost a whole $9 each.. and guess what.. I want to replace them with better servos that won't strip gears or break gears if I land a bit to hard or have a minor crash.. these servos WILL strip or in my case, break gears into little pieces. the Gyro works... but not great. it doesn't hold the tail as well as a gy401 or a LT2100 would.. it drifts pretty bad. I have a Wfly radio.. it's crap... it does it's job of letting me fly, but for programming options or using it on other heli's, forget it. so when someone tells you to not buy cheap electronics it's because most likely, THEY'VE been down that road before and are just trying to help someone else from making that same mistake...
< Message edited by Kaelan -- 3/7/2008 3:39:07 AM >
_____________________________
Gaui Hurricane 550 CF HeliPro BlackHawk 450SE
